Replacement headlights 2003 SC430
I am looking for a quality aftermarket pair of headlights with led trim or running lights for my 2003 SC430. Any thoughts and or pictures?
These are fantastic. I had them on my 430.
Philips 12824WLVWAC1 DayLight 8 Gen 2 High Powered Luxeon LED Daytime Running Light https://www.amazon.com/dp/B005DX6BKW..._rzW9CbBA40BX2
I don't think you'll find what you're seeking without buying complete assembled replacements and "splitting" the lenses, then adding your own LED array, resealing the lenses and figuring out how to wire them.
It's pretty easy to polish out the lens. The mechanical self leveling can be fixed too. There are no full replacement headlights with what you are looking for. Every is custom and quite expensive. OEM replacements are really expensive as well.
There weren't enough sc430's made to make it profitable for the aftermarket to make different headlights for it. That's not as cheap to design and produce as say body kits. Headlights also have to get DOT approval helping drive that cost up even more. Stock headlights are it, with some mods you can do to them.
rclab1
01-03-09 03:42 AM
