Engine light bulb was ripped off
Old 06-17-19, 10:21 AM
forplatina
forplatina's Avatar
Default Engine light bulb was ripped off
Hi,
I live in France (so sorry for my english)...
My engine light bulb (cluster) was broken (ripped off).
Do you know if it's possible to replace it ? I don't know the reference.
It's very important for me because the light engine must work for the technical inspection in France.
Thanks
My model is a SC430 2003
Old 06-17-19, 10:37 AM
VVTiBob
VVTiBob's Avatar
Is the entire speedometer, also called the “combination meter” gone/stolen? Or is it just damaged?
Using google translate.....
L’indicateur de vitesse complet, également appelé «compteur combiné», at-il été volé? Ou est-ce juste endommagé?
Old 06-17-19, 10:55 AM
forplatina
forplatina's Avatar
Just damaged.
The former/previous owner had put silicone in the hole to hide the engine light. removing the silicone, I tore the bulb of the engine light .....
And my "computer assy" reference is : 83800-24170 (km/h only). Do you know if I can buy an other speedometer in England (miles + km/h) with the reference : 83800-24180 ? It will be compatible ?
If yes, I can install this used speedometer to do my technical inspection...
Old 06-17-19, 12:14 PM
TaninAuto
Sponsor
CL Vendor - Starter
TaninAuto's Avatar
We can repair/replace the light. Send us a message.
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
The following 2 users liked this post by TaninAuto:
Coleroad (06-17-19), VVTiBob (06-17-19)
Old 06-17-19, 02:46 PM
VVTiBob
VVTiBob's Avatar
J'allais suggérer Tanin. Ils parrainent le club Lexus et leurs membres ont obtenu des résultats positifs. En outre, un indicateur de vitesse neuf ou usagé présenterait très probablement un problème kilométrage kilométrique si les inspecteurs tiennent des registres. Si Tanin ne peut pas le réparer, ils savent comment remettre à l'état le compteur utilisé.
Old 06-17-19, 05:34 PM
GmanSC
GmanSC's Avatar
English translation:
I was going to suggest Tanin. They sponsor the Lexus Club and their members have achieved positive results. In addition, a new or used speedometer would most likely present a mileage problem if inspectors keep records. If Tanin can not fix it, they know how to reset the counter used.
Old 06-17-19, 11:01 PM
forplatina
forplatina's Avatar
Thank you for your help.
I will contact tanin if I can not find another solution. Because I'm sure they can help me but shipping costs to send my speedometer to the US should not be cheap....
In France we have meter specialists but they are not used to working with Lexus because it is a weakly sold brand
Old 06-18-19, 10:47 AM
DshngDaryl
DshngDaryl's Avatar
Can you take a picture of the damage. There is a good chance you can fix it. You just need a bulb in the spot that can light up.
Otherwise, I believe the speedometer from England should work. I assume they both work on a european standard. Is this the one you are talking about?https://www.ebay.fr/itm/Lexus-SC430-...4AAOSwLM5bD-5k
A speedometer specialist can probably fix your speedometer. Even though it is a lexus, it is really a Toyota Design. Chances are, they are only going to solder in an led or light bulb
Old 06-18-19, 12:43 PM
forplatina
forplatina's Avatar
Hello, This is exactly what model I bought.
I want to use the "bulb" of the English version to solder it on my French speedometer. It should work.
The speedometer specialist who looked at my speedometer (he is apparently not very good as a specialist according to the opinion ...) needed to know the voltage / electric tension of these bulbs to order the right ... . If you have this information it would allow me to order only the missing bulb without having to disassemble that of the English speedometer ...
I also contacted another specialist who is much better recognized. He would simply know the electrical diagram of the speedometer at the connector/ping to plug it "on the table" to test without having the SC430 with him.
So if you also have the schematics for the speedometer spindles.
And this is my french speedometer : http://zupimages.net/viewer.php?id=19/25/fe6e.jpg ( 83800-24170)
I hope that my translation is understandable and thank you in advance.
Ps :
I take this opportunity to show you my baby lol (it is a very rare model in France. I never met on the road) :
Old 06-18-19, 02:48 PM
DshngDaryl
DshngDaryl's Avatar
That is a nice looking car.
Old 06-18-19, 03:21 PM
ivanj
ivanj's Avatar
Default Thumbs up for Tanin
Tanin does great work. When I sent the core back I was dismayed but not surprised how much the original was monkeyed with. There maybe more problems with your cluster under the covers.
Tip - with the broken display, take the car to an official inspection station; in most states, anyway, a mileage/kilometer reading will be taken and registered. Then Tanin can set the speedometer to a small increment more than was recorded officially. Then you have an official mileage record, as far as I know, on CarFax or its French equivalent.
Someone correct me if I am wrong. I don't want cause a diplomatic incident!
Old 06-18-19, 03:40 PM
VVTiBob
VVTiBob's Avatar
What year model is your car? I ask because the tail lamps in the video are 2006+ but the photo of speedometer is from the 2002-05 year models. If the tail lamps were changed without changing the board in the luggage compartment, the tail lamp out indicator light on the speedometer will light up. Because the lamps are LEDs and the 02-05 lamps were incandescent bulbs.
En quelle année est votre voiture? Je pose la question parce que les feux arrière de la vidéo datent de 2006+, mais que la photo du compteur de vitesse est celle des modèles de 2002-05. Si les feux arrière ont été remplacés sans changer le tableau du coffre à bagages, le voyant lumineux des feux arrière sur l'indicateur de vitesse s'allume. Parce que les lampes sont à LED et les lampes 02-05 étaient des ampoules à incandescence.
Old 06-18-19, 11:34 PM
forplatina
forplatina's Avatar
My year modèle is 2003. And yes, I changed the tail lamps without changing the board.
I have the indicator light but I have hidden with a small piece of felt (carpet)
For the inspection, in France we haven't "carfax" (US) or carpass (like Belgium).
I think the simplest solution would be to recover the Light "warning engine" of the English speedometer to weld it on my french speedometer
Old 06-19-19, 05:33 AM
ivanj
ivanj's Avatar
forplatina: Pour nous rappeler notre patrimoine culturel et académique, ma femme et moi utilisons l'option Français ' sur le système de navigation Lexus.
Old 06-19-19, 02:54 PM
forplatina
forplatina's Avatar
Smile
Sympa c'est un bon moyen de travailler la langue. Je devrais faire pareil avec l'anglais afin de m'améliorer !!!
Quick Reply: Engine light bulb was ripped off
