tire wear on SC430s
hi, i have a 02 sc430 in so.calif. have 29K miles on orig. RFT . . . .loud/noisy.. anyway,
i've noticed that the front tires are both scrubbing /wearing more on the inner treads... i've rotated them and the fronts are doing it again....
the car is in good alignment....
does the sc come with exaggerated toe in/out or weird camber?
otherwise my tread wear is quite good still.... probably would have another 20K in 'em....
i drive mostly freeway....
j.rho
02 sc430 silver/ecru
remote engine on/top up/down
j.rho
I know what you are talking about, I had the same problem on my SC. The inner tread on all 4 tires wore down to the WIRE with only 20K Miles on it. If I remember the front 2 tires wre the worst. The further out on the tire the better the tread started to work. The dealer said that I as pretty much out of luck :-( Let me know if you find out any anwsers.
-Ian
-Ian
WeekendDIY
12-19-19 03:53 PM
dozvette
06-15-12 08:31 AM
redspencer
11-23-10 03:14 AM
