A/C Screen
A/C Screen
How do I get to and clean the other side of my A/C screen, please? It is foggy. around the left side, I believe because of an ineptly-used steam cleaner.
I believe that’s an anti glare coating that’s been degraded over time, and abrasive cleaning solutions.
check this thread...https://www.clublexus.com/forums/sc4...ol-lcds-6.html
more specifically posts 107 and post 146-149.
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
262-456-4147
Use a pick or suction cup, double sided tape, etc. Most of them fall off/pop off without much resistance.
__________________
262-456-4147
262-456-4147
The LCD screen is different than the product in question, which is the anti glare plastic / lens
__________________
262-456-4147
262-456-4147
So replacing the anti glare will not help with the "degraded" look?
See the picture on our product link and/or compare it to your climate control to see if the anti glare lens will solve your issue. Or you can upload a picture of your climate unit here and we can tell you what will solve the problem.
__________________
262-456-4147
262-456-4147
I will snap a picture and post here...thanks.
Removal
__________________
262-456-4147
262-456-4147
I think I like your suction cup idea better, since the pick seems to damage the screen. Of course, if you are replacing the one you take off, I guess it wouldn't really matter.
You could also drill a small hole in the lens to pull it out if you are concerned with scratching the plastic bezel. Or put some tape down, or a cloth, etc to protect the plastic.
__________________
262-456-4147
262-456-4147
Here's mine...$99 fix?
