RESOURCE MATERIALS: 2002-2010 SC430 Technical Service Bulletins (TSBs)
This thread is intended to be a Technical Service Bulletin (TSB) resource for 2002-2010 SC430 Owners. Files will be added from time to time on an irregular basis.
Unfortunately files larger than five (5) megabytes cannot be posted to the Club Lexus Website. There are two TSBs that fit that criteria that I am aware of.
They are:
Finally the naming conventions used... it has changed over time, but the consistent portion seems to be the last two digits of the file name which represent the year the document was published. That’s why i added a more descriptive title to the file’s name.
They are:
- L-SB-0008-15 Reception Diagnosis using Antenna Test Kit (6272kb)
- L-SB-0025-14 Immobilizer and Smart Key Reset (6655kb)
The following 7 users liked this post by VVTiBob:
Bgw70 (08-31-19),
Bluetheron (01-17-21),
digitatc (08-30-19),
Harold57 (09-04-19),
ivanj (08-30-19),
and 2 others liked this post.
The "Customize Features" TSB sometimes referred to as C-BEST is one of the more useful TSB. You’ll find it here:
https://www.clublexus.com/forums/att...-functions.pdf (L-TSB-SS004-01)
or a prettier version, without all of the CBEST functions, for our SC430s is below:
If anyone has other TSBs that apply to 2002-2010 SC430s that are not already posted in the messages above, please feel free to add them to this resource.
SC430 Service Data Sheet - Published in August 2005*
* NOTE: You may be prompted to add “Asian Fonts" to your Adobe Reader the first time you try to open this document. I did so without any issues on my Windows10 PC.
JMal (03-23-20)
drive belt
I just purchased a 2002 SC 430. Has 35,000 original miles on it. Should I replace the water pump and drive belt if its never been done? It has always been in Arizona or California. Lexus says it's about $1500.
Hi just purchased an Sc430 in the Uk after two days roof will not open
if I disconnect the battery then reconnect it then works
And closes normally.
It then fails again and I have to cycle the power to operate it open
I am sure this problem is common
do you have any ideas
i have noticed I have to slam the boot shut to reset the open switch
thanks appreciate any help
the problem has currently rectified itself since cycling the battery connection
many thanks if it returns I will post on discussions.
DaveGS4 (03-28-24)
