Wheel spacer help with 245/45/18
do any of you guys running spacers have the vehicle lowered? any rubbing/issues?
I used 20mm front to clear the Supra BBK and 35mm on the rear. It sits flush.
Scrub radius is off so your turning circle is wide however it's more stable and has less body roll.
I have used a hubcentric spacer for more than 40K miles and no issues whatsoever on the wheel bearings. Control arm bushings however will suffer a premature wear.
