2008 sc 430 39k miles
Not lowered now
Front wheels 20x9 et32
Rear wheels 20x10.5 et30
I'm comfortable with running a 275 30-20 on the rear however my main question is the front tire . I really would like to run a 255 30-20 in the front but I do not want to have to roll any fenders and at some point I might want to put meister coilovers on the vehicle. I would prefer not to have to deal with any rubbing issues as well. Does anybody have any advice on the 255 front application ? Goodbye stock wheels and ride height
Any help would be appreciated. Thanks... Robert
Not sure this is helpful to you, but I was running a staggered 21" setup: 21x9 + 22 with a 255/30/21 and a 21x10.5 + 34 with a 295/25/21 lowered on Tein S-Tech springs and I only rubbed on big bumps/reverse at full lock.
I've dropped down to a 19x9 + 15 and a 19x10 +20 with 245/35/19 and 275/35/19 that's being installed this weekend. I'm now running coilovers so I expect to be able to set things up for daily with no rubbing ever.
Thanks for the info. You gave me exactly the info I need. Moving forward with 245 35-20 in the front and 285 30-20 in the rear. Once I get some pictures I will let you know how it goes. Once again thanks for taking the time out to share your information
I'm currently running F235/35/19 and R275/30/19. The ride is so bad so I'm changing to F245/40/19 and R 285/35/19.
Low profile is nice for look but ride comfort is no where to be found.
I'm glad it was helpful! I debated on 285/30/19, but I because of the aggressive fitment of the new wheels, I wanted to rub a slightly narrowed tire for fitment. Also, I need more sidewall height for daily use, thus the 275/35.
Can't wait to see pics and I'll post up mine next week.
Exactly why I changed my mind and went with 275/35. The -30 looks good, but I'm expecting -35 to ride better and not damage my wheels.
For you to get an idea what it might look like.
I just replaced the 2 rear tires with 285/35/19 today. It's huge. And the fender gap is huge as well . I can't justify to spend extra $ for coil over since I just replaced the rear shocks like a thousand miles ago.
Here is a 275/35/19 on a 19x10 if this helps at all. The visible different between XXX/30 and XXX/35 was minimal, so I opted for the thicker sidewall for the better ride.
so I ended up running 245 35-20 with a 20 by 9 ET 32 on the front and a 285 3020 on the rear 20 x 10 and 1/2 e t 30. Everything fits perfect. Just ordered the Meister coilovers today. I'll send pictures after it gets lowered.
hey mate, interested in the 21 COR wheels you had for sale, are they still around?
