OEM or Equivalent Suspension Bushings
Get MOOG K500101 & MOOG K500102 with 555 stamp. They are made by Sankei in Japan, which, I believe is the OEM for Toyota/Lexus.
You will need to spray some paint if you buy this. They come in bare metal without paint and get rust easy.
And there they are.
https://rover.ebay.com/rover/0/0/0?m...2F264277468183
Bookmarked for later. These may be gone but there will be more.
Now one thing I did notice were grease fittings on these plus some other aftermarket brands. Do the OEM's come with grease fittings on the ball joints? I'm at work so cant look now. I sure would be interested to know if there are any points that should be greased that I was not aware of. Thanks.
Paul
Paul
OEM doesn't have Zerk grease fitting.
You better go with Rockauto. They have the Moog for about $30 each.
I used the Moog with zerks. Like you said, I guess it really doesn’t matter which type you use.
I tried to locate the moog part numbers I used by logging into my Rockauto account, but no luck. I suppose I didn’t log in when I made the purchase.
bentleymp2
Suspension and Brakes
01-08-16 09:28 AM
GS4TEK
05-07-12 08:44 PM
