AFS Light Flashing After Bulb Change
AFS light is flashing after headlight bulb change on my 2007. Is there a reset? Did I knock something loose?
Any direction appreciated.
Thanks!
Thanks!
If it flashing, probably something got disconnected. Try to turn it off and on or disconnect the battery. I don’t know if there’s a eay to reset it.
Adapted Front Lighting System (AFS) moves your headlights left or right according to your turning. The switch is below the fuel door and trunk release switches.
Thanks for answering.
This thread, paying attention to post #9.....https://www.clublexus.com/forums/sc4...ing-light.html
BTW the search tool is really really helpful. For example searching AFS will present the answer.
Post number 9 offered no answers to my situation.
Thanks for the reply.
Now it doesn't work.
I am unsure how replacing a bulb would suddenly make the height sensors not work. Especially when I didn't touch them during the bulb replacement process. Headlights work fine otherwise. They dip up/down on startup.
Thanks for your reply.
Maybe I wasn't clear. My AFS worked fine since I've had the car. It worked fine Friday. Then I merely changed a burnt out headlight bulb.
You must accidentally knocked something loose.
Any chance you put in a defective or an incorrect light bulb in?
When parts and electronics get old often the breaking point just takes a little nudge. The sensors are directly related to the functionality of the system. Go back and trace your work. If nothing appears to be wrong at the headlight assembly check the height sensors. We can only offer suggestions, you are the one who actually did the work. Maybe the motor just decided to bite the dust. Techstream might be able to tell you the exact fault.
Headlights working fine too.
masboy
GX - 1st Gen (2003-2009)
29
12-16-10 06:30 AM
