How did u make this work? Is this a direct replacement to the stock screen? Does it affect the stock radio in any way? Does the stock screen control the climate control? Thanks
EVGENY,
This is really a great idea. You can even use this unit to read a TPMS system or to read a Bluetooth OBDII Adapter
I wouldn't get your hopes up too high about the TPMS, I doubt that it will work with the Lexus TPMS system. IIRC, the SC430 TPMS is a proprietary system that is not just data off of the OBDII port. However, that would be really cool if it could.
I also have to wonder about the steering wheel control access for the same reason.
All that said, I will be interested to see what all can really be done with it if someone takes that project on. For less than $100, that Android device could be the cat's meow.
Hi everyone,
Yes it is replacement to stock monitor, music playing via stock radio.
For tpms i had bought tpms for android. It shows pressure and temperature for every wheel.
Hi everyone,
Ah, now that makes sense. I like being able to actually see all the information on the sensors.
