Water Bubble on Convertible Flap
Order some new tires for the SC430 (General Altimax RT43's) and while inspecting the car I noticed a bubble on my convertible flap similar to the one below:
Would an upholstery shop be able to fix this? Ty
Called the “package tray” an air bubble has formed under the leather where gasses gathered. I had this same problem. A small imperceptible puncture will allow the air/gasses to escape allowing the leather to return to the original position.
DON'T USE GLUE!!! Poke a small hole in the middle and use a hair dryer to warm up the entire area, then just work the bubble out. There is a youtube video if you do a search for air bubble on vinyl dashboard.
It sounds easy enough however this would be my first time doing such thing. Will look at a professional and see what they can offer and gaurentee.
Ah VVTiBob, its good to have feedback from you. How was your results? This is usually a spot that gets no attention but once the top is down, it is visible.
Thanks! I'll check it out and thank you again for your feedback.
The following 3 users liked this post by MrIanB:
what holds the material in place when they build the package tray?
guess I made a mistake five years ago when I fixed mine...
https://www.clublexus.com/forums/sc4...back-dash.html
Bgw70 (02-07-20)
counselguy
04-01-06 05:17 AM
tsopranoMB
Southeast
07-18-05 11:31 AM
