Just wonder where would you tab the 12V for your DRL under the hood? Thanks.
I had to run a power supply wire into the car to the drivers side fuse box. There is a open spot for a mini spade fuse at the bottom of the center row of fuses (not used). I soldered a wire at the front of a 10 amp fuse to obtain power. Be certain when installing fuse that the circuit side is on the load side. Works without any concerns.
One confusing problem I encountered though...There are two different double contact bulb numbers. One will short out and blow a fuse...sorry I forgot which is the correct application. I would have to pull the bulb to get the number.
no need to disassemble headlight. Just use the existing turn signal bulb socket. The socket is already wired for double contact bulb....just need to add constant on feed. Looks good day or night!
