Is a 1/2 (10-150 ft.-lb) torque wrench able to do most jobs on the Lexus Sc430?
Hey guys, getting ready to do my valve cover replacement, along with the spark plugs. I have already invested in the complete 2004 sc430 service manual set, Mini VCI cable for techstream and have already acquired my valve cover gaskets and the other components that it came with. Just waiting on the spark plugs. While waiting I noticed that I do not have a torque wrench, and if I expect to work on my car on my own, this is something I definitely need. No need to break the bank. Everything I have bought has been very cheap through eBay. I don’t know if there is a particular need to get a 1/4, 3/8, and 1/2 torque wrench. Should I get all of them? I Can only afford one at the moment, so would a 1/2 (10-150 ft.-lb) torque wrench be a good option to work on most (if not all) car components in the sc430? Thank you in advance. I am looking into the Tekton click torque wrench which is listed at only $40.
Get a 3/8, just my suggestion. 1/4 is too small and 1/2 is massive...
this, and if you are interested torquing everything you could get a inch pound wrench for the small things. That 1/2 like iolmaster said will do most of what you need.
Guess we’ve got a Tie!
Walk into a harbor freight and pick all of em up for half the cost lol
How’s the quality?
the half inch is 9.99 with coupon. Dont know about the other ones though. Might price them with coupons to see how you compare
Edit: All three should total 30 bucks new
You can always get one and do a torque test. This is a simple way to do one.
But you should really splurge and get the teckton or at least a Harbor Freight Pro. Their cheapest line of tools always seem like a good idea until you use them in a serious manner.
I have the 3/8 and 1/2. I use the 1/2 most often, but if I was buy one for the valve cover gaskets and spark plug job, I would go for the 1/4 with inch pounds. The valve cover bolts are spec'ed at 53 inch pounds, which equals 4.4 ft.lbs.. The spark plugs are 13 ft.lbs. (156 inch lbs.) and the coil pack bolts are 66 inch lbs. The valve cover bolts and spark plug torques are critical, so you definitely want a good quality torque wrench for this job.
I've been wrenching so long that I rarely need a torque wrench, except on large, critical bolts, i.e., brakes, suspension, wheels. However, if I do need to tackle the valve covers on my SC, I'll be investing in a quality, 1/4 torque wrench that can index inch lbs. I wouldn't necessarily trust HF for a critical tool like this.
and thanks for sharing your knowledge.
