I'm looking to purchase a headlight restoration kit. Any recommendations? There are a couple of different Meguiar's kits, Rain-X, 3M....are they all pretty much the same? Any tips or advice for actually doing the restoration?
It won’t be easy. Lots of work, not like wipe on-wipe off, I can tell you that. Depends on how bad your headlights are, sometimes you can get away with just tooth paste, other times you have to sand it down with 400 or 800 grid sand paper. I used to restore my Corolla headlights, spent many hours and they still looked little dull, probably from inside. The sun UV done quite the damage on those plastics.
I've used both the 3M and the Rain-X. Both work well. Once back to clear, you can coat the restored lenses to preserve the polishing with a Meguiar's product called Headlight Coating.
One recommendation I have is that you mask a good 2' around the headlight. The polish sprays everywhere when you use power tools, and once dry, it takes some effort to remove. I use a cordless drill to polish mine, although I have also used a corded drill in the past, as well.
It's a lot of work, but you can get good results if you put in the time. However, the results never last as long as a new headlight lens, even with the Meguiar's coating product. The best results are gotten by replacing with new, then coating, to prevent fogging. I'm experimenting with new OEM on my wife's ES, and new aftermarket on my Tundra. On my SC, I've only polished and coated once in the four years I've owned it.
Too, keeping the vehicle headlights out of direct sun slows down the fogging, but this is easier said then done. I cover my SC, since I don't have room in the garage for it.
^ Thanks Wilson. I've seen some videos and hey usually say to tape the paint. I was wondering if there was a coating or a film of some sort to protect the headlights when you're done. My car lives in the garage overnight, but as my DD, is outside all day, so I should get something to protect them going forward.
expel plastic protective film. Pre cut to fit. That is if you have a pre 06 . That's truly the best option. If its post 06, you can cut a piece or have it done at a shop.
So let me get this straight. You park a Tundra Pickup in the Garage and let the SC sit outside? Now I get letting the wife park her ES in the garage because we all know a happy wife is a happy life. But parking the pickup inside over the SC, man that is shameful. (just kidding)
Unfortunately, I live in the San Francisco Bay Area where a million $'s nets you a one-car garage! To ease your mind, I have a $350 car cover that protects the SC very well. I've literally only washed it about one time per year in the four years I've had it. But, each time I drive it and return home, I wipe it down with a detailing spray before covering it again.
I have used the Lex dealer for my headlight cover restoration in conjunction with detail job. They do a great job on my 2003. The kits are a giant pain in the neck, and results are nowhere as good.
Not sure why you think the kits don't work well. They work great and are pretty easy if follow the instructions. User error is often why people get poor results. Don't forget to protect the lens after you clear it.
I found trough trial and error that you can use a cleaner wax to clean that top yellow layer off of the headlights. Unfortunately, you will need to use that cleaner wax every 6 month to keep the headlight crystal clear. Even if you use a top coat wax or sealer after the cleaner wax the sun will deteriorate it and the yellowing will start again.
I saw a few youtube videos where a spray clearcoat was applied after the cleaning process and they said that would do the trick... I did not do that so I can't be sure.
The option that has worked on my 2002 sc430 was using the meguiars headlight restoration kit, around $15.
It has been about 2 years since I did it and have been very satisfied with the results.
good luck!
