Polishing wood trim
Polishing wood trim
Not sure if there is/was s thread about this, but I polished the wood in my car this weekend.
When shining a bright light on the wood, was a bit surprised at the micro swirls/scratches in the wood...just from age and use.
So I polished it much like you would car paint since the wood has a pretty decent clear coat on it like your exterior paint.
I used a Lake Country orange hand pad cut into a 1" square or so. I used HD Speed all in one as the polish. And of course a bit of elbow grease!
Came out spectacular...depth is impressive. I was negligent taking before pictures...but did snap one after picture.
Easy project to do if you're bored.
Lavrishevo (05-24-20)
wood?
Paul
leexed (05-25-20)
Nice work! I haven't heard of the pad or polish brands you used. Are they specific for polishing plastic? Before reading your post, I would have likely tackled this job with any brand of plastic polish I had on hand, like Meguiars, and a microfiber cloth.
Although I think, in the end, we're splitting hairs. It's the clear coat that gets the scratches anyways.
**EDIT** Just checked the sales brochure and real wood is mentioned multiple times. Hand chosen for grain consistency too, apparently.
**EDIT 2** Apparently, Yamaha Fine Technologies has been doing the Lexus wood since the onset. The wood itself is only ~ .2mm thick (.008") The wood, aluminum and adhesive composites combined are less than 1mm thick (.04").
No..these are car paint polishing items. Since the wood is covered with a clearcoat (as is the exterior of the car) I used those items in the same way I remove micro swirls from the exterior. Albeit with gentle hand rubbing and not a machine.
