Meet Samantha, my newly bought 2005 SC430
His girl might have some issues. It's very difficult to say for sure, but the body lines appear to be off on the drivers side rear. Plus, if he can see daylight from under the door sill on the passenger side, He has some major damage. First off would be to pull the passenger seat and carpet back to find out just how much damage to the floor plates etc., then have the frame checked. I think he knows all of this already. I just hope it doesn't turn into too big of a project to get her back on the road safely.
Paul
Paul
Foxfire413 (07-31-20)
It opens just fine, but it needs help closing. The right roof pin that fits into the hole near the windshield is too high, while the left fits just fine. I close it 90 percent of the way, push down the roof with my left hand, then press the close button with my right. (While standing outside the passenger door)
Hopefully Lexus allowed some adjustments to be made near the hinges, otherwise I'll have to get crafty with a solution. Any tips would be appreciated.
Paul
Well, this is what I can tell you about the top. There is only one user adjustment that sets the proper gap of the middle hinge point. I was trying to think of anything else it could be. And this is a reach. One of the main drive motors could have slipped a tooth during the impact. "I don't believe it mind you" because you say that it closes just fine with some assist. That to me means that the tops final position is straight and even across the top where it meets the windshield with no unusual gap from one side to the other. This would also tell me that the front latches that secure the top are also engaging. You have not mentioned whether or not you are throwing codes though. What I do believe is that the impact did indeed twist the frame. You have cross bracing under the frame for stiffening. One of more of these braces may have been knocked out of alignment or are damaged. Good luck and keep us informed.
Paul
Paul
Paul
Paul
Foxfire413, one of the symptoms of motor mounts going bad is hoses coming loose. Also, as these cars age, the vacuum hoses get hard and crack. So be sure to check out both of these, as your hoses may be telling you that you need new motor/transmission mounts and since you have to reconnect the hoses, check them out to determine whether it is time to replace them also.
Foxfire413 (08-01-20)
My mechanic said the exact same thing about the motor mounts! Luckily the hoses are still soft and malleable, I suspect it will need the motor mounts though.
Prasha
11-04-16 11:57 AM
RemyMartin
06-05-08 10:00 AM
