Climate Control - Won't blow hot or cold air
4th Gear
I have a 2003 SC430, and my Climate Control Cluster seems fine. I can adjust the blower up and down or change the mode. All functions seem to work. Except that if I raise temps the heater won't blow hot air, and if I lower the temps, the A/C won't blow cold air. What would cause this?
Does this failure apply when the controls are in "Auto", dual. Do the blowers change speed trying to meet temp request? If yes, then it is most likely a failed blower door motor. There have been quite a few threads on this subject. Try a forum search and you should find quite a bit of information. Good luck.
Paul
Paul
4th Gear
Nor do I have any heat coming from any of the vents. Raising the temps to 85 does not make the heat come on, and lowering the temps to 65 does not make the AC come on. It will blow vent air at whatever blower setting I use, low or high. Thanks for your help.
Are both passenger and Driver side giving you trouble? I think there are 4 blend doors in the SC, it seems like if both sides are giving you trouble, it wouldn't be caused by just one door.
What I would do is disconnect your battery for a few minutes. After you reconnect it, the blend doors will open and close to learn their position. That may fix your problem.
If not, you can read this post. It maybe a fuse issue
https://www.clublexus.com/forums/sc4...004-sc430.html
Have you tried pushing your recirculation button? Maybe you will get some air that way. If you do, I would say it is probably your blend doors.
As I was writing this, I recalled you can have your car do an A/C self test. Here are the directions for a LS, but they should be same for the SC
https://www.clublexus.com/forums/ls-...ditioning.html
There is a thermistor somewhere in the AC/Heater loop. I bet that your problem. Do you have TechStream or any kind of code reader? If you don’t, take your car to a mechanic, he should find out the problem.
It could be the actuators as Daryl said above. I will post some threads for you.
you can change the temp and look under the dash to see it the temp actuator is moving.
there are four actuators. One on drivers side, three on passenger side.
The four actuators control,
1. drivers side heat and cold
2. passenger side heat and cold
3. fresh or recirculated air
4. air direction, floor, defrost and vent.
Actuators buzzing sound.
https://www.clublexus.com/forums/sc4...s-are-hot.html
this is all about actuators from the GS forums...the actuators operate the same.
https://www.clublexus.com/forums/gs-...ete-guide.html
the last post in this thread has files showing the actuator locations.
TimEricson
15
05-08-10 10:41 PM
