Bad Camshaft Position Sensor
Old 10-10-20, 09:03 AM
GOLDSc300
GOLDSc300's Avatar
I would say AMG batteries are not much more expensive. Needless to say that my next battery for the SC will be AMG. Thanks for the good suggestions. The comment about a special AMG charger is an interesting one. I will google it. Also AZ summer is a way more hotter compare to CA and just for that reason AZ batteries are not last longer than 3-4 years.
Old 10-10-20, 11:06 AM
Bgw70
Bgw70's Avatar
I know what you guys mean but Mercedes Benz builds the AMG...the battery is an AGM.
I am not trying to be sarcastic or rude...
WIL44 (10-12-20)
Old 10-10-20, 02:40 PM
Wilson2000
Wilson2000's Avatar
So many acronyms, so little brain cells left! Thanks for the catching this before it got further out of hand!
Old 10-10-20, 03:51 PM
GOLDSc300
GOLDSc300's Avatar
Sure, the battery is an AGM. Thank you for pointing out. Btw, AGM batteries do NOT require a special charger.
Old 10-11-20, 01:57 PM
Wilson2000
Wilson2000's Avatar
Originally Posted by GOLDSc300
...AGM batteries do NOT require a special charger.
One of my AGM's went completely dead, and would not take a charge from several of my battery chargers. I took it to where I bought it and they were able to charge it over night with their AGM charger. I've heard of this phenomenon from multiple sources since then.
Old 10-11-20, 10:16 PM
Caflashbob
Caflashbob's Avatar
The sc is not made to charge an AGM correctly. Slightly higher voltage than agm’s like. That being said I have an AGM and a smart temp compensating battery tender charger as I drive the car rarely.
Old 10-12-20, 11:58 AM
DshngDaryl
DshngDaryl's Avatar
I think it may apply to all batteries though. Modern chargers won't charge a battery when the voltage gets too low. It essentially doesn't see the battery. I saw SAMCRAC on youtube hook his dead battery to his car battery and then the charging cables to his bad battery. This gave the charger enough reading to start the charging process.(I don't know if I would do that, but he claims to do it all the time)
If you have an old, dumb charger. You can just hook it up to the battery and it will charge without checking.
I also heard somewhere that if you trickle charge a battery that has been sitting for awhile, you might be able to revive it. It has to do with the trickle charge (12 hour) cleaning off the lead plates or something, whereas a quick charge (1 hour) doesn't do that.
Old 10-12-20, 01:26 PM
Wilson2000
Wilson2000's Avatar
Thanks DD...all good information! In my case, I tried two different modern chargers and one specifically noted that it worked on AGM's. I even tried the trickle setting overnight. Then, I tried my big-old-toaster-sized charger that I have been using for 45 years. None did the trick, before returning to the AGM dealer for a charge. However, I still haven't seen enough evidence for a dedicated AGM charger to make me go out and spend $130 for a fourth charger! I would almost prefer to switch back to wet-cell technology as opposed to adapting to the quirks of AGM's, especially after hearing in an earlier post that the charging voltage of the SC is too high for AGM's.
Old 10-12-20, 04:37 PM
DshngDaryl
DshngDaryl's Avatar
Take a look at this PDF and tell me if I am reading it right. I had no idea that there was an optimal charging voltage for a battery, but now that I think of it, that makes total sense. According tot his PDF, it seems like our alternators put out 14.4 volts, which is .2 volts too little for the optimal charge.
https://www.centurybatteries.com.au/...y-charging.pdf
Is that how you read it?
LexSaZ
11-07-23 10:20 AM
pfrose6
GX - 2nd Gen (2010-2023)
23
08-08-21 06:34 AM
iAxX
10-26-18 02:52 AM
stevesturm
08-22-17 11:41 AM
johnnylt
03-15-16 05:23 PM
Quick Reply: Bad Camshaft Position Sensor
