Trans flush
Guys...I don’t think it works that way...the “drain Plug” is used to make sure you have the correct level.
Above the drain plug is a tube. This tube keeps the fluid at a certain level...the level must be set at a certain fluid temp...I might have the procedure...it is not complicated, just a PIA...
It's somewhat confusing because you are using the drain hole as a level indicator. That's the purpose of the level-tube, which can be removed or installed with an Allen wrench through the drain hole. This info is all assuming a closed SC tranny is designed the same as a closed ES tranny. I'll check my SC shop manual to see if it addresses the procedure.
mi-is350
RX - 4th Gen (2016-2022)
343
02-07-24 08:12 PM
Moustafa
12-21-20 10:12 AM
pschall
11-21-19 04:52 AM
