Brake failure. Trying to figure out what happened.
#92
Well I got the data from the EDR today and I can't tell heads or tails from it. It doesn't give any errors codes and it says the brake was engaged for a while and ten finishes with that it wasn't engaged. It doesn't look like any error codes were showing just that the brakes stopped engaging. Here's the data if anyone knows how to read it.
DATA LIMITATIONS
Refer to the CDR report for data limitations
SYSTEM STATUS AT TIME OF RETRIEVAL
ECU Part Number 89170-24060
ECU Generation 00EDR
Freeze Signal OFF
FRONT/REAR EVENT RECORD SUMMARY AT RETRIEVAL
Most Recent Frontal/Rear Event 2
1st Prior Frontal/Rear Event 1
Prior Frontal/Rear Event 0
SIDE/ROLLOVER EVENT RECORD SUMMARY AT RETRIEVAL
SYSTEM STATUS AT FRONT AIRBAG DEPLOYMENT
Time to Deployment Command, Front Airbag, Driver (msec) Not Commanded
Time to Deployment Command, Front Airbag, Passenger (msec) Not Commanded
Event Severity Status, Driver N/A
Event Severity Status, Passenger N/A
Diagnostic Trouble Codes Exist No
Buckle Switch, Driver Unbuckled
Buckle Switch, Passenger Unbuckled
Ignition Cycle Since DTC was Set (times) 0
Airbag Warning Lamp ON Time Since DTC was Set (min) 0
SYSTEM STATUS AT EVENT (MOST RECENT FRONTAL/REAR EVENT, TRG 2)
TRG Count 2
Time From Previous TRG (msec) 5,100
Time from Pre-Crash to TRG (msec) 300
Shift Position Drive
LONGITUDINAL CRASH PULSE (MOST RECENT FRONTAL/REAR EVENT, TRG 2 - TABLE 1 OF 2)
Max Longitudinal Delta-V (MPH) -5.1
Max Longitudinal Delta-V (km/h) -8.3
LONGITUDINAL CRASH PULSE (MOST RECENT FRONTAL/REAR EVENT, TRG 2 - TABLE 2 OF 2)
Time (msec) Longitudinal Delta-V (MPH) Longitudinal Delta-V (km/h)
10 0 0
20 0 0
30 0 0
40 0 0
50 -1.7 -2.8
60 -1.7 -2.8
70 -1.7 -2.8
80 -3.4 -5.5
90 -3.4 -5.5
100 -3.4 -5.5
110 -3.4 -5.5
120 -5.1 -8.3
130 -5.1 -8.3
140 -5.1 -8.3
150 -5.1 -8.3
PRE-CRASH DATA, -5 TO 0 SECONDS (MOST RECENT FRONTAL/REAR EVENT, TRG 2)
Time (sec) -4.3 -3.3 -2.3 -1.3 -0.3 0 (TRG) Vehicle Speed (MPH) 17 16 15 10 9 9 Vehicle Speed (km/h) 27.4 25.7 24.1 16.1 14.5 14.5 Brake Switch ON ON OFF OFF OFF OFF Accelerator Rate OFF OFF OFF OFF OFF OFF Engine RPM (RPM) 400 800 400 400 800 800 Pre-Crash Data Status * Valid Valid Valid Valid Valid Valid
SYSTEM STATUS AT EVENT (1ST PRIOR FRONTAL/REAR EVENT, TRG 1)
TRG Count 1
Time from Pre-Crash to TRG (msec) 100
LONGITUDINAL CRASH PULSE (1ST PRIOR FRONTAL/REAR EVENT, TRG 1 - TABLE 1 OF 2)
Max Longitudinal Delta-V (MPH) 0
Max Longitudinal Delta-V (km/h) 0
LONGITUDINAL CRASH PULSE (1ST PRIOR FRONTAL/REAR EVENT, TRG 1 - TABLE 2 OF 2)
10 0 0
20 0 0
30 0 0
40 0 0
50 0 0
60 0 0
70 0 0
80 0 0
90 0 0
100 0 0
110 0 0
120 0 0
130 0 0
140 0 0
150 0 0
PRE-CRASH DATA, -5 TO 0 SECONDS (1ST PRIOR FRONTAL/REAR EVENT, TRG 1)
Time (sec) -4.1 -3.1 -2.1 -1.1 -0.1 0 (TRG) Vehicle Speed (MPH) 4 6 9 7 6 6 Vehicle Speed (km/h) 6.4 9.7 14.5 11.3 9.7 9.7 Brake Switch OFF OFF OFF ON OFF OFF Accelerator Rate OFF OFF OFF OFF OFF OFF Engine RPM (RPM) 800 800 1,200 800 800 800 Pre-Crash Data Status * Valid Valid Valid Valid Valid Valid
SYSTEM STATUS AT EVENT (PRIOR FRONTAL/REAR EVENT, TRG 0)
TRG Count 0
Shift Position N
LONGITUDINAL CRASH PULSE (PRIOR FRONTAL/REAR EVENT, TRG 0 - TABLE 1 OF 2)
Max Longitudinal Delta-V (MPH) -34.3
Max Longitudinal Delta-V (km/h) -55.2
LONGITUDINAL CRASH PULSE (PRIOR FRONTAL/REAR EVENT, TRG 0 - TABLE 2 OF 2)
10 0 0
20 -8.6 -13.8
30 -17.1 -27.6
40 -25.7 -41.4
50 -32.6 -52.4
60 -34.3 -55.2
70 -34.3 -55.2
80 -34.3 -55.2
90 -34.3 -55.2
100 -34.3 -55.2
110 -34.3 -55.2
120 -34.3 -55.2
130 -34.3 -55.2
140 -34.3 -55.2
150 -34.3 -55.2
PRE-CRASH DATA, -5 TO 0 SECONDS (PRIOR FRONTAL/REAR EVENT, TRG 0)
Time (sec) -4.3 -3.3 -2.3 -1.3 -0.3 0 (TRG) Vehicle Speed (MPH) 0 0 0 0 0 0 Vehicle Speed (km/h) 0 0 0 0 0 0 Brake Switch OFF OFF OFF OFF OFF OFF Accelerator Rate OFF OFF OFF OFF OFF OFF Engine RPM (RPM) 0 0 0 0 0 0 Pre-Crash Data Status * Invalid Invalid Invalid Invalid Invalid Invalid
PIDsStart
0 A0 FE 0 0
1 0
3 0
9 30 30 30 30 30
0A 30 30 30 30 30
0B 30 57 30 39 30
0C 30 57 30 39 30
0D 32 34 30 36 30
0E 32 34 30 31 30
0F 32 34 30 31 30
11 44 4E
12 32 34 30 36 30
13 1
14 8
15 0 74
16 FF FF FF FF FF FF 17 FF 0 0 0 FF FF 18 0 FF FF FF 0 0 19 FF FF FF FF FF FF 1A FF FF FF 0 0B 24 1B 37 42 48 4A 4C 4D 1C 4D 4D 4D 4D 4D 4D 1D 4D 4D 4D 4D 4D 4D 1E 4D 42 28 16 0B 5 1F 2 0 0 0 0 FF 20 0 0 0 0 0 0 21 0 0 0 0 0 0 22 0 0 0 0 0 0 23 0 0 0 0 0 0 24 0 0 0 0 0 0 25 7F 0 7F 0 7F 0 26 0 0 0 0 0 0 27 7F 7F 7F 7F FE AF 28 0 0 FF FF FF FF 29 0 92
2A FF
2B 44 45 44 45
2C 30 57 30 39 30
31 44 4E
32 32 34 30 31 30
33 1
34 1
35 0 6A
36 37 42 48 4A 4C 4D 37 4D 4D 4D 4D 4D 4D 38 4D 4D 4D 4D 4D 4D 39 4D 42 28 16 0B 5 3A 2 0 0 0 0 FF 3B 0 0 0 0 0 0 3C 0 0 0 0 0 0 3D 0 0 0 0 0 0 3E 0 0 0 0 0 0 3F 0 0 0 0 0 0 40 FF FF FF FF FF FF 41 FF 0 0 0 FF FF 42 0 FF FF FF 0 0 43 FF FF FF FF FF FF 44 FF FF FF 0 0B 24 45 FF FF FF FF FF FF 46 FF FF FF FF FF FF 47 7F
48 7F
49 7F
4A 92
4B FF
51 44 4E
52 32 34 30 31 30
53 1
54 1
55 0 6A
56 37 42 48 4A 4C 4D 57 4D 4D 4D 4D 4D 4D 58 4D 4D 4D 4D 4D 4D 59 4D 42 28 16 0B 5 5A 2 0 0 0 0 FF 5B 0 0 0 0 0 0 5C 0 0 0 0 0 0 5D 0 0 0 0 0 0 5E 0 0 0 0 0 0 5F 0 0 0 0 0 0 60 FF FF FF FF FF FF 61 FF 0 0 0 FF FF 62 0 FF FF FF 0 0 63 FF FF FF FF FF FF 64 FF FF FF 0 0B 24 65 FF FF FF FF FF FF 66 FF FF FF FF FF FF 67 7F
68 7F
69 7F
6A 92
6B FF
6C 30 30
BE 0 0 0 0 1 1 BF 1 2 2 2 2 3 C0 3 3 3 FF 2 3 C1 0 0 0C 0 1
C2 7 7 8 0C 0D 0E C3 2 2 1 1 2 1 C4 0 0 0 0 0 0 C5 0 0 0 0 0 0 C6 0 0 0 FF 1 1 C7 0 0 20 0 1
C8 5 5 6 7 5 3 C9 2 2 2 3 2 2 CA 0 5 0A 0F 13 14 CB 14 14 14 14 14 14 CC 14 14 14 FF 0 3 CD 0 0 0 FC 0
CE 0 0 0 0 0 0 CF 0 0 0 0 0 0 D0 AA AA AA
D1 0
D2 0 0 0 0
D3 0 0 0 0
E0 C0 10 0 0
E1 0 0
E2 0 0
EC 0
PIDsEnd
DATA LIMITATIONS
Freeze Signal OFF
TRG Count 2
10 0 0
20 0 0
30 0 0
40 0 0
50 -1.7 -2.8
60 -1.7 -2.8
70 -1.7 -2.8
80 -3.4 -5.5
90 -3.4 -5.5
100 -3.4 -5.5
110 -3.4 -5.5
120 -5.1 -8.3
130 -5.1 -8.3
140 -5.1 -8.3
150 -5.1 -8.3
TRG Count 1
10 0 0
20 0 0
30 0 0
40 0 0
50 0 0
60 0 0
70 0 0
80 0 0
90 0 0
100 0 0
110 0 0
120 0 0
130 0 0
140 0 0
150 0 0
TRG Count 0
Shift Position N
10 0 0
20 -8.6 -13.8
30 -17.1 -27.6
40 -25.7 -41.4
50 -32.6 -52.4
60 -34.3 -55.2
70 -34.3 -55.2
80 -34.3 -55.2
90 -34.3 -55.2
100 -34.3 -55.2
110 -34.3 -55.2
120 -34.3 -55.2
130 -34.3 -55.2
140 -34.3 -55.2
150 -34.3 -55.2
PIDsStart
0 A0 FE 0 0
1 0
3 0
9 30 30 30 30 30
0A 30 30 30 30 30
0B 30 57 30 39 30
0C 30 57 30 39 30
0D 32 34 30 36 30
0E 32 34 30 31 30
0F 32 34 30 31 30
11 44 4E
12 32 34 30 36 30
13 1
14 8
15 0 74
2A FF
2B 44 45 44 45
2C 30 57 30 39 30
31 44 4E
32 32 34 30 31 30
33 1
34 1
35 0 6A
48 7F
49 7F
4A 92
4B FF
51 44 4E
52 32 34 30 31 30
53 1
54 1
55 0 6A
68 7F
69 7F
6A 92
6B FF
6C 30 30
D1 0
D2 0 0 0 0
D3 0 0 0 0
E0 C0 10 0 0
E1 0 0
E2 0 0
EC 0
PIDsEnd
#93
My first question...hope it is not a dumb question.
what is an EDR?
is this data from the Lexus or Bosch engineer?
what is an EDR?
#94
It was pulled from my Lexus by the Bosch engineer on behalf of Lexus.
#95
I think this is the pertinent section. Apparently it didn't cover more than the last 5 seconds
#96
I'm surprised the technician didn't record any error codes out of the other box that mechanics always read because I could swear he said he pulled it and it said ABS failure and that is probably why the brakes failed because these cars disable the brakes when that happens.
#97
One would hope there is a report coming with some type of analysis. Have you been told anything along those lines?
Rich
Maple Valley, WA
2006 SC430 Red Mica Metallic/Camel
Rich
Maple Valley, WA
#98
I was told that Lexus was getting a copy and I was getting a copy and that they would be in touch. Of course that was mailed out Friday from my area so I got it yesterday. I imagine it will be a few days for them.
#100
Guys, I think since we are not engineers , the bottom line is
did the brakes had 100% failure due to lack of service or
Maintenance or did it fail due to an engineering issue ?
The argument the car is X years old is flawed because unless
The car was never serviced in 100K+ miles , I have never
heard of any modern brakes loosing complete brake failure
#101
#102
Exactly! Unless Lexus can show you abuse the brakes and never ever serviced them
in 100K ( black fluids , brakes down to 1MM, rotors all groved out etc)
I would try to seek legal damages if they won’t repair your SC.
Thanjfully you were not hurt but at minimum, they should
repair and repaint your SC. Bodily injury is the most costly
in a lawsuit. The manufacturer would quick pay for repairs
if you can show the ABS system was not abused in any way
for the full failure.
#103
So here is an update. I had to call Lexus headquarters to find out they had closed the file. They said they weren't going to to discuss it with me BUT they may want to buy it back under the lemon law. That will take 4 weeks. I took the car to my Lexus dealer, whom I trust and they examined the brake system. They couldn't find anything wrong except for one ABS sensor being disconnected. Everything else was perfect. They checked everything and even the pads were in great shape.
So now the question is could a loose fitting to an ABS sensor cause the car to turn off the brakes. Is it safe to drive? I don't know.
#104
A lose or disconnected ABS sensor should have generated a warning light or at least stored a code for it. I wouldn't drive it. Rent a vehicle and charge the cost to the settlement.
#105
If Toyota wants to buy it back, they probably found something very wrong and know they have another recall on their hands.
dbryan, did you happen to let Toyota know what you do for a living?
do they smell litigation coming their way ;-)
