Carlaoer Android Car Install
#31
Thanks really love the system. Huge step up from the oem navigation and wireless CarPlay is fantastic
The CarPlay adapter I got from Carlaoer accepted firmware update just fine
After some frustrating efforts trying to get a steering wheel button assigned as microphone in android and recognized as Siri button, I got a steering wheel button assigned to Siri
Requires two steps. First android needs a steering button learned as the play button
Second. Have autokit learn that button as Siri. It must be the button that android has learned as play
#32
Polish
Freshly completed print. You can see the wavy supports that were needed to print the overhanging mounting ledges.
The support material peels away quite easily if the printer settings are correct.
Leaves the overhanging support ledges that fit over front Android display surface
Fits well, but surface of 3D print is made of 0.15 mm layers. Curved, top, surfaces simply are not smooth if left just as printed.
One nice thing about PETG is it can be sanded and polished to look better than the layered/stepped appearance of a 3D print.
Some wet sanding, micromesh sticks refinement, and nail polishing stick yielded my final gloss finish.
#33
I've said it once and I'll say it again... your work is extremely impressive! Nice job with the surround, not only refining it, but the polishing really ties the whole unit together. Sounds like you've got the software configured close to dialed too! Looking forward to seeing if Tasker works for you.
Side note, i got the OBDLE unit in the mail on Saturday and couldn't pair it to my phone or Android. After looking in the box I saw it came with instructions that state you must install an app to assist with the BT pairing. Did you need to use their app? Seems a bit sus to require an additional app for a standardized protocol.
#34
Didn’t use their app. Actually didn’t read their instructions. Just plugged in and started use. No pairing just direct selection in apps of the OBD device. It is designed to communicate direct without pairing Bluetooth
#35
Could you please take a screenshot of the About from the unit? Just want to make sure it's hackable/rootable to run custom ROM. I'm thinking about the 9" model that stretches from air vent to vent. Thanks.
#37
That's interesting... I've only ever used OBD modules via pairing with Bluetooth. You're saying you didn't have to connect via Bluetooth, it just automatically recognizes the device once in Torque or the like? I tested on both my Android phone and head unit and neither were able to recognize an OBD device. I must have received a faulty unit. I requested a replacement and should have the new one later this week. Fingers crossed that one works.
#38
Odd to receive a bad unit
engine was running when you attempted connection right?
The plug with two short blue antenna wires and video input is plugged into back of android?
#39
I don't recall using a plug with any antenna wires, just the primary harness (which I reduced to Pwr, Gnd, Acc and Reverse), the AV harness (AUX out, Video, in/out, USB), and GPS. Unless those antenna wires were part of the AV harness.
I didn't have any issues connecting to my last OBD device using my Android phone, so not sure what the issue is now. Hoping I received a faulty unit, although I suspect that isn't the case. I figured maybe since Torque Pro doesn't show ELM (only options are Bluetooth, Wifi, USB) as an OBD2 adapter type in the settings menu, maybe that was the case. So I downloaded OBD Fusion which is a recommended app on the device's amazon page. This app has ELM as a connection type, but still couldn't connect to the device.
#40
Mine is working fine with Torque Pro on the Carlaoer Android. I recall it would never pair under the Android bluetooth app, but was able to directly select it in Torque Pro.
OBD fusion talks to it without pairing on my iPhone.
#41
Hi Seattle SCone , I have been going nuts trying to figure out how I could make a surround for my android head unit that didn’t look ugly. .. thanks for sharing the 3D print file . Got a quote in NZ $ 43 , probably about 30$ USA . So am very happy with that. , thanks again Bruce.
#43
NZBruce (01-14-21)
#44
Have not installed Tasker yet, but at least have Torque Pro configured to show the parameters I'm interested in knowing. Didn't see much utility in adding displays that are already on the dashboard. So, no tachometer, speedometer. This is the view of the Android with Torque Pro at night.
hlthlnk (02-25-21)
