valve cover gasket
valve cover gasket
hello ,brand new here ,was hoping to find a video or a good explanation on how to change valve cover gaskets on my 2002 sc 430 ...thank you
i haven't found a good one, but here is one for the LS430, which is VERY Similar to the SC. It is pretty much the sedan version
I haven't watched this video, but hopefully it will help you
Paul
DshngDaryl (03-02-21)
Very easy to do using the videos for the LS430 or even the 2001-2007 toyota sequoia.
I have a 2002 sc430 with over 150000 miles and just changed both gaskets.
Glad I did it, the gasket was so brittle.
Take your time with the project...you are going to encounter several small hoses that are also brittle and can crack as you move them out of the way.
Good luck!
Good luck!
