Wind noise
Old 03-03-21, 03:56 PM
whlng88
whlng88's Avatar
Default Wind noise
Hi, when travelling above 70kmph, my 2001 SC430 has a noticeable wind leaking into the car now. When I press against the inside rubber seal just above the side mirror, noise is reduced significantly. Instead of changing the entire seal, is there an elegant ( & cheaper &#129322 way to solve this ? Many thanks 🙏🏻
Old 03-03-21, 04:13 PM
mmarshall's Avatar
There might be a cheaper way, although I'm not sure it's more elegant: Try using some high-adhesive duct or similar tape that is reasonably close to the color of the interior trim around the seal. That might cover up the small air-leaks where you are getting the noise.
whlng88 (03-03-21)
Old 03-03-21, 04:49 PM
Received 3,030 Likes on 2,545 Posts
Problem is you're driving 70,000 mph.
The following 2 users liked this post by LeX2K:
Rayzerr (11-21-23), SGB4570 (11-21-23)
Old 03-03-21, 06:13 PM
mmarshall's Avatar
I think the OP meant 70 KPH, which is about 44 MPH in the U.S.
whlng88 (03-03-21)
Old 03-03-21, 07:45 PM
whlng88
whlng88's Avatar
Default Wind noise
Many thanks to all who responded. Will research on adhesive tape. Haha yes I live in Singapore so it is metric km. Yes indeed I should have used KPH the OP. Many thanks 🙏🏻
Old 03-04-21, 08:58 AM
DshngDaryl
DshngDaryl's Avatar
this is actually a common problem. google "clublexus sc430 wind noise" and you can find several creative fixes.
Old 03-04-21, 10:58 AM
implantgs4
implantgs4's Avatar
In my opinion, just replace the rubber molding surrounding the side-view mirror. It is a pretty easy job and there are some great guides on this web-site. I had wind noise and tried using some of the methods that are listed in some of the pages to make sure the noise was coming from the side view mirror. Once I had pin-pointed the noise was coming from the side view mirror, I replaced the molding on both sides and it was whisper quiet inside.
Old 03-05-21, 05:43 AM
bmanone
bmanone's Avatar
implantgs4,
Do you have a part number for the rubber molding surrounding the side-view mirror?
Thanks!
Old 03-06-21, 06:42 AM
implantgs4
implantgs4's Avatar
Sorry, I don’t, but it is listed in one of the wind noise threads.
Old 03-06-21, 07:23 AM
Harold57
Harold57's Avatar
Here is a thread. Check out posts 37, 72, 95 & 109. (There's more information in the thread too but those should get you where you want to be.)
https://www.clublexus.com/forums/sc4...ml#post5681301
Old 03-06-21, 04:26 PM
bmanone
bmanone's Avatar
Thanks for the links...
Old 03-09-21, 03:35 AM
whlng88
whlng88's Avatar
Originally Posted by bmanone
implantgs4,
Thanks!
hi, my mechanic is sourcing the part for me. I will ask him for the part number when the part is ready for installation
Old 03-09-21, 05:18 AM
gbdad
gbdad's Avatar
That's too bad, because I REALLY wanted to see an sc430 going 70,000 mph...bummer
Old 03-09-21, 10:14 AM
Harold57
Harold57's Avatar
The part numbers are listed in the posts of the link that I posted earlier.
Old 03-09-21, 03:22 PM
whlng88
whlng88's Avatar
ok great thank u Lexus Champ 👍
Quick Reply: Wind noise
