A/C Problems
Sorry for the late reply. Not hard at all. I have the lexus manual both volumes just in case I had to do some work on the top mechanism. No i didnt replace the condensor. You only replace it if your compressor craps itself. The filter is on the side of the condenser and i think you can replace it seperately. But most just replace both since you have to take it out and off the car to replace it.
There is a c-clip that holds it in place. You can probably just use 2 picks and squeeze the together to take it away from the edges or just buy a cheap pair of c ring pliers from harbor freight. Then just use a pair of grip pliers and tug on the top of the valve.
You should see two small holes around the edge. Thats the clip you have to compress inward to remove it. It would be great if that fixed your problem. Have any more questions dont be afraid to ask.
Got the c-ring out (have the correct pliers). Just was afraid to use vice grips to get the valve out. Got a new one coming so guess shouldn't matter. Thanks for the quick reply.
DshngDaryl (06-05-22)
Sounds good! congrats on your success. Keep us posted
OfnaRcR
IS - 1st Gen (2001-2005)
09-10-13 06:32 AM
USAF_RT
Performance & Maintenance
07-07-07 12:22 PM
