Front strut concerns
Old 05-06-21 | 01:54 PM
gbdad's Avatar
gbdad
Exclamation Front strut concerns
Put on the front KYB struts with strut boot over the weekend and, with everything put back correctly, have a noise that sounds like metal on metal...advice please!? Is there something I forgot (ie new strut mounts from KYB?) I'm in a bind!
Old 05-06-21 | 06:13 PM
DshngDaryl's Avatar
DshngDaryl
Does the metal on metal sound come from somewhere under the driver's seat?
Old 05-07-21 | 04:54 AM
gbdad's Avatar
gbdad
No, it sounds like near each shock, no sure of origin. Why do you ask under the driver seat?
Old 05-09-21 | 10:40 AM
DshngDaryl's Avatar
DshngDaryl
There is a headlight level module under the car under the driver's seat. It is known to make a scraping sound. Mine made the noise when a passenger got into the car.
Then one day it quit making the noise, so I am not sure how to fix it.
Old 05-10-21 | 06:53 AM
st3rnly's Avatar
st3rnly
Did you torque everything with the car suspended and knuckles hanging or supported at ride height? Either way, I would go back under the car and re-torque everything. Look for any parts that have rubbed while you're under there.
Is it a rotational sound? When is the sound present?
Old 05-10-21 | 08:26 AM
gbdad's Avatar
gbdad
Not a rotational sound, mostly on bumps, but not on smooth pavement...What the*
Old 05-11-21 | 10:20 AM
digitatc's Avatar
digitatc
I just changed to coil overs and I'm experience the same noise. I probably forgot to torque something correctly...
Old 05-11-21 | 05:48 PM
Seattle SCone's Avatar
Seattle SCone
Recheck your sway bar links as well. My rear links drive me mad for a long time. I had checked and they seemed tight to the rear sway but eventually discovered they were the source of metallic clink noises. Took a Chassis Ear to locate the noise source was at the sway bar to link hardware.
Old 05-23-21 | 11:31 PM
digitatc's Avatar
digitatc
Here is another one you'll need to check, the top nut on the strut, make sure you torque it to specs after the spring settles.
WtSpyder (05-24-21)
MASSMINI
RX - 1st Gen (1999-2003)
10-25-20 07:07 PM
fabchef
07-09-20 06:41 PM
realsync1
08-06-19 12:51 AM
jwigley
18
03-15-16 03:12 PM
