Everything You Need to know about a Car Battery
It is my 5 Year Anniversary on ClubLexus. I joined May 2016
In those 5 years, I have seen a lot of discussion about Batteries, Trickle Chargers, Parasitic Draws, Bad Alternators and the like.
I am of the belief that if you have an AGM battery and do not set the alarm in your car (You manually lock the car with the interior door locks), plus shut off your radio and Automatic Headlights, your car can sit for a month and still start up. I know it works for my SC, because I just got in yesterday, after a month of sitting, and it started up with no problem.
Anyways, here is a video from my favorite YouTube car mechanic covering everything you need to know about your battery. I think you will find it helpful:
Daryl ...actually after a year of troubleshooting this battery enigma on my 2005 ; your recomendation is spot on . I think I may have read your recomendations in the past and tried doing what you suggested . It works ! thanks
DshngDaryl (05-12-21)
I will have to try that. I know if I hit the lock button in the car (The one that locks all the doors simultaneously), it will arm the alarm. If I manually flip the button by the latch it shouldn't (but might, I have never tried it)
Ah, I did not think about flipping the switch. You’re absolutely right. I just went out and tried it. No alarm set. One problem though, you can not lock both doors. When you exit the car, both door are unlocked, so locking only driver side won’t do any good. I wonder if TechStream can change that. It might. I’ll look into it later.
Still, you should be able to flip the lock on each door individually and get out without it unlocking one.
Preserve settings and AAA batteries
https://youtu.be/YC--MLNIbik
2. If my battery is at 10V with the engine off is it time to replace it? Does the low voltage make the alternator work harder?
3. I have an inexpensive trickle charger set up but I have found that if I do not lock the car in my locked garage, even this crappy battery will hold the charge longer.
Congrats to DshngDaryl! Between Chris Fix and Scotty (and my friend Raoul) one is hardly ever led astray.
1. If I replace the battery myself with a Group 46 AGM, or have AAA replace it, how do I retain the settings for the electronics or is that a non-issue?
#3, yes, a trickle charger will help even a bad battery. But don't rely on it, replace the battery.
a 10V battery according to Chris Fixx means you have a bad cell in your battery Since your battery is used to start your car and the alternator is used to keep your car running, my layman's answer is, no it does not cause your alternator to work harder.
I have to disagree with you here Daryl. The alternator is going to try to charge the battery and if the battery voltage is low, it will be drawing more energy than normal. This extra drain will place an extra strain on the alternator.
Maybe the voltage regulator might be computer controlled, but I don't know enough about our system to answer that.
I'll spare you the calculations but the voltage drop will cause an increase in the wattage dropped across some of the alternator components. The increased wattage will increase the temperature rise. Correct, the alternator won't be able to increase speed to increase the energy output but will still "feel" the strain.
I tend to agree with Daryl. The alternator spins at constant speed driven by the belt, which produces constant voltage which regulated by the voltage regulator in turn feeds to the battery. If the battery voltage dropped due to the dead cells, I don’t think the alternator will “know”, just the battery fails to receive the charge. Alternator fails because its internal mechanical and electrical components are wear and tear or short of life.
