Got a new seat position ecu and swapped it out with the old one. New seat position switch. No movements from the 8 way control. All but the one circled on the black connector are showing 12.4 volts with a multi-meter. What next??
In studying the schematics, I have a question for those who understand them better than me. In the photo below, the item circled in red appears to get power from the second photo showing the driver side. My question is which pin on the cream connection block from the passenger floor is associated with the circuit in question?
First, let me say thanks to all that have helped with diagrams and other information. This is what this group is all about.
Below is another photo of the white connector coming from the floor on the passenger side. I have labeled each of the lines with the color wire associated with it. In the electrical schematics provided above, a R-L (Red -Blue) is shown to be coming from the driver side to the passenger seat ECU. I do not see this color line in the white connector. This R-L line shows going to the passenger door ECU first. then becomes a B-Y (black - yellow) going into the sliding roof control ECU. It leaves there as a G (green) going into the passenger seat ECU. Is this the larger gauge LG (light green ) linge in the white connector coming from the floor?
Blue - Orange 12.54v
Blue - White 12.54v
Pink - Blue 1.00v
Green w/silver 1.00v
Blue w/silver 0.00v
Brown 0.00v
White - Black 0.00v
Blue - Yellow 0.00v
Light Green 0.00v
With engine running:
Blue - White 12.54v
Pink - Blue 1.00v
Blue w/silver 0.00v
Brown 0.00v
White - Black 0.00v
Blue - Yellow 0.00v
Light Green 12.54v
Does anyone know what each of the lines from this connector do? Is this the correct state for not running and running?
The connector you are showing on the passenger side is BE1…Drivers side is BD1
most of the wires you labeled match my diagram.
This is great information! Is there a table that identifies each of the numbered ports? I see in your following post that the line coming from the roof ECU goes through connector BE1 as a green wire, in and out, which number is it on the connector?
thanks again, just not familiar with reading these things.
I will help you understand how to read them…BTW, I may make errors.
go to post 54, look at the green wire at BE1,
next to BE1 is the number 10.
Now go to the connectors pic for BE1…
now go to your connector pic,
turn your pic over to match my connector pic.
What color is that wire?
Appears to be a green wire with silver tick marks on it. If that is the feed, is the constant 1.00v correct?
