Camber settings
Camber settings
MeisterR and upper control arm upgrades completed. It is indeed quite the improvement even for a conservative driver like me! 😁
Alignment at tire dealer done today.
Their printout shows front camber settings at -1.5 deg and -1.8 deg.
(All other measurements are in spec).
Cam bolts on lower control arms are frozen--they suggested I spray with PB Blaster.
I've learned this negative camber can improve handling in curves.
How much additional tire wear could I see with these settings?
Toe is close to zero. 0.06 0.08 deg.
Buster06 (06-07-21)
If you're primarily a highway cruiser or inner-city driver, the additional negative camber isn't going to be of any real benefit to you, and will wear your tires quicker than zero camber. I tried close to zero camber before getting my alignment and absolutely hated it. Understeer for days and the car behaved extremely sluggish when trail braking into corners.
cjinthesky (06-08-21)
Thanks for the useful information! Understeer has been a handling gripe; certainly feels tighter in turns now.
Any input on adding cam bolt near bottom of coil over / top of steering knuckle, to complement the usual one on the lower control arm?
I have run camber values near yours and usually get my Pilot Sports to last about 20,000 before replacement. I do notice inner wear is > outer wear, but 20K isn't bad for sticky tires. The road grip with keeping new rubber on the car is worth it. That 20K miles translates to about 4 years use because they are on the vehicle only during warm 1/2 of year.
FIGS
IS F (2008-2014)
06-22-12 09:17 PM
