Roof
Roof
So just bought a 03
Needs a little work
One been the top
Rear windows are down and top doesn't go down
I check the sensor in the back
I'm going to check the fuses
And since the power button red light is not coming on I'm thinking it maybe it...
What else?
I'm going to check the valet button in glove compartment too
Thank God I got it cheap
And there is a pretty cool aftermarket stereo system
Any help is appreciated
Needs a little work
One been the top
What else?
Any chance it was rear ended?
No LED that means bad news. If you have TechStream, you can record the codes.
The reason I ask is because the sequence of a roof opening is:
1. windows
2. trunk opening
3. Package Tray up
4. Roof retracts
5. etc
6. etc
Your windows open but the trunk isn't opening. That is usually tied to a latch that is on the back wall of the trunk (the side closest to the license plate) If the latch got damaged or bent, then the trunk will not open and the opening procedure will come to a halt.
1. windows
2. trunk opening
3. Package Tray up
4. Roof retracts
5. etc
6. etc
wcabili
06-11-15 10:59 PM
