Reset vsc
Old 06-16-21, 05:52 PM
docjenn
docjenn's Avatar
Default Reset vsc
Reset of VSC
After trying to reset VSC after techstream use on '05 it never flashes VSC with paper clip to reset. Any ideas?
Old 06-17-21, 12:14 PM
Bgw70
Bgw70's Avatar
Originally Posted by docjenn
Reset of ESC
After trying to reset ESC after techstream use on '05 it never flashes ESC with paper clip to reset. Any ideas?
I think you mean VSC, are you using pins 4&14, key on engine off?
docjenn (06-17-21)
Old 06-17-21, 05:31 PM
docjenn
docjenn's Avatar
Default Res
Tried paper clip to short 4-14, turn key to on but light for VSC goes off but never flashes. Will make reset tool and try that when Male OB2 connector comes. Wondering if there was anything else to try in the meantime.
Old 06-18-21, 09:46 AM
DshngDaryl
DshngDaryl's Avatar
is your vsc switch (by the heated sears) turned to on?
Old 06-18-21, 12:05 PM
docjenn
docjenn's Avatar
Switch is on, works correctly for about 20 seconds then VSC lite comes on along with VSC off in dash. Trying reset with paper clip VSC lite never flashes with paper clip at 4-14 with key turned on.
Old 06-18-21, 02:24 PM
docjenn
docjenn's Avatar
I have 4 located 4th from left side side and 14 on narrow side 3rd from right. Is that correct?
Old 06-18-21, 03:43 PM
docjenn
docjenn's Avatar
Don`t know what I did different but on 100th try VSC lite and ABS flashed together and now lites are off! Thanks.
Old 06-19-21, 01:19 PM
Harold57
Harold57's Avatar
[img]file:///C:\Users\ASUS\AppData\Local\Temp\msohtmlclip1\01\clip_image001.jpg[/img]
Old 06-21-21, 06:45 PM
jimisbell
jimisbell's Avatar
I have a question??? What is that method of reset for? My VSC and VSC OFF lights are on and I cannot turn them off but the car seems normal. The reset button to the left of the steering wheel does nothing.
Old 06-22-21, 07:41 AM
docjenn
docjenn's Avatar
This turns off the VSC lite and VSc off in dash.
Old 06-22-21, 12:03 PM
jimisbell
jimisbell's Avatar
Permanently, temporarily, or because it corrects a malfunction? What is the reason to try this?
Old 06-22-21, 03:40 PM
Bgw70
Bgw70's Avatar
when the lights are on, the VSC is disabled…be careful driving.
Old 06-22-21, 03:52 PM
jimisbell
jimisbell's Avatar
so what does the VSC do?????
Old 06-22-21, 05:16 PM
Bgw70
Bgw70's Avatar
Jim, please read your owners manual…
Old 06-22-21, 07:12 PM
jimisbell
jimisbell's Avatar
I( have read the owners manual. You misunderstood my question! Do not assume the person asking the question is a dummy. I find the CL to be very friendly in most part, but in the SC-430 area, not so much. Most areas, answers are freely offered and the questioner is not berated.
As to MY question, you stated the I should be careful driving while the lights are on and my reading of the manual suggests no such warning is necessary. And if it was dangerous to drive with it lit, I am sure there would be NO switch to turn it off, and there is.
My original questions were trying to determine WHAT are we trying to cure...other than lights on the dash .....which are not in any way harmful.
Quick Reply: Reset vsc
