Techstream user’s question.
Do you have techstream? I need to know if it will assist with the diagnosis of issues with the seats. Will it report fuse failure, does it communicate with the seat controller?
thanks
thanks
It will not check a fuse but it will communicate with the seats
I have Techstream, ordered from EBay. It loaded properly into my Dell laptop with Windoze 7 but it wont run. It keeps asking me for a "New Code" and when I cannot supply it, it blocks me from moving forward. Anybody know what it wants??
Jim
Getting Techstream to run is a real PIA I think either GmanSC or BG 70 can best answer your question. I could try and explain it but I am sure I would just confuse you more.
Dennis
Dennis
![](https://cimg7.ibsrv.net/gimg/www.clublexus.com-vbulletin/998x749/8c0e69b7_15a1_4c9d_9e04_293d5df05c7c_ccc019c3255eb09ba6b65022ce7d7ace25d30e26.jpeg)
Your disk should have a crack file and/or passcode file. Run the file, it will put the passcode to the registry. Talk to your vendor if you don’t have the files.
Jim,
if you can not get your TechStream installed and ran, for get your software and download version 12.
It’s already cracked and patched. Just install. Dennis installed this version.
Link be low:
http://blog.obdii365.com/2017/05/09/...free-download/
Good luck.
Link be low:
Good luck.
Jim, if you decide to install version 12, you must completely uninstall your currently installed TechStream. For more discussion on TechStream subject, read this:
https://www.clublexus.com/forums/sc4...utions-11.html
