Car Completely Dead
Went to start my 2006 this morning. It sounded like a normal start for a second and then everything went completely off. All systems dead. Battery is completely charged. Any ideas?
It sounds like you have a loose battery cable. Check the cables on the top of your battery. If those are tight, then you will have to crawl under your car and check your ground.
Bgw70 (06-25-21)
I doubt that you have loose terminal or ground. It’s your battery that went dead. Try to recharge your battery. If it die again, time for new battery or alternator. Hopefully it's your battery just discharged.
Since battery is charged, check the main fuse. There was another thread on this a few months ago.
It turns out that it was the positive battery clamp. Although the screw and nut was as tight as it could be the clamp was still loose around the terminal. I think it was distorted from removing it over the years. Bought a new clamp at AutoZone, not identical but I got it to work. Thank you all for you suggestions.
The following 3 users liked this post by inscents41:
They sell Battery Shims, or battery caps to solve the problem. This will keep you from having to change the battery terminal
https://www.autozone.com/batteries-s...E&gclsrc=aw.ds
Unfortunately, if the techs (possible grease monkeys) who work on one's vehicle aren't adept at their trade (over-tight is right), they can f-up one's clamp for life! This is just one more reason I don't let anyone else touch my vehicles. If anyone is going to f up my one of my vehicles, it's gonna be me!
Good call Daryl! Glad that you got it resolved inscents41.
akafixture
03-12-17 02:23 PM
kqt2ktval
12-12-06 07:42 AM
