Nav Screen door will not close
Anyone have a idea of how to reset the Nav screen door it won’t tilt or close, is this a common problem or can it just be reset somehow? Also I can get my cup holder cover to open ?? And helpful information is appreciated.
Thanks!
Thanks!
The NAV door may have a fuse that you can check, or the mechanism may have jammed or jumped the track.
are you mechanically inclined?
You will need to remove the nav screen unit and cup holder for inspection
When I got my car someone had spilled a soda and the cup holder was stuck down. I had to work it open and then clean up the syrup.
DO NOT TRY pouring water on it (like my sister did in her mini cooper), since there are electronics in that area.
CAREFULLY using steam would work also
RADIO1 - fuse # 8 in engine compartment
PANEL - fuse #2 in driver’s side kick panel
DOME - fuse # 4 in passenger’s side kick panel
RADIO2 - fuse # 9 in the passenger’s side kick panel
if these fuses are ok, you have the motors problem. There is the thread that cover this issue. Just do a search for it.
Someone028
01-12-22 11:03 AM
jayare1231
07-23-17 11:46 PM
