"compact spare"?
Yes, there have been a few threads about this. Years ago, I bought an old Supra spare (from the 90s). I believe the Mazda RX8 I believe did also but it is a smaller tire but also lighter.
Bgw70 (08-01-21)
Yes there is a ton of info out there on the forum for spare tires and spare tire installation kits including lists of the parts needed and the part number that goes along with it. You may find it confusing and expensive but you can "Getter Done".
https://www.clublexus.com/forums/sc4...n-started.html
Dennis
Dennis
Bgw70 (08-01-21)
I am not looking for "installation kits" or multiple parts, I am just looking for a wheel with rubber on it that I can specify in an ebay search. I will just throw it in the back where the hole is.
they are all providing the information you need Jim
Dennis
Dennis
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
Jim, did you try searching the SC430 forum?
Compact spare in title
https://www.clublexus.com/forums/sc4...patibilty.html
Spare in title
https://www.clublexus.com/forums/sc4...ubstitute.html
https://www.clublexus.com/forums/sc4...pare-tire.html
https://www.clublexus.com/forums/sc4...-sc-430-a.html
dozens more threads out there with answers.
Spare in title
Bgw70 (08-01-21)
Yes I searched. The only thing I got was Camry...without a year. The threads all present parts numbers for installation kits and parts. I just want to know what the year and make of a car spare that has the propper bolt circle. I dont want to install ANYTHING. I just want to know the year of that damned Camry.
Forum Administrator
Then search for Camry spare year in the sc430 forum if that’s what you are looking for
or rx7
https://www.clublexus.com/forums/sc4...rks-sc430.html
or is350 (also address Camry year in post 36)
or rx7
OK, guys, I give up. Those tires were ALL 17" wheels. I dont know about yours but my SC430 has 18" wheels.
I will just go to a junk yard and search their inventory its easier than pulling hens teeth.
Yes, the standard SC430 spare tire is a 17" wheel, bolt pattern 114.3 x 5, tire size 145/70R17.
Forum Administrator
From my reading those threads, I believe the OEM SC430 spare is 17" . That (and the width) are why it's a called a "space saver" and why your SC430 trunk / top will operate with it in the slot and I'd guess it won't with an 18" spare.
It's not meant to be a full size OEM replacement for any distance. Lexus would not have used that size for the OEM spare if it was unsafe.
That spare is what comes with the spare tire kit. But remember, the spare's wheel size is 17" but the spare tire size is is 140/70. I just went and measured my spare and my tires (standard 18") and they are the same height.
