Sc430 06 need help on ecu compatibility
Good morning to all!
I need to find an ECU for my 06 SC430. Mine's part number is: 89661-24760 but I haven't been able to find one with the same part number after 3 months searching... Are there any other ECUs compatible with my car or the rest will not work correctly?? I don't care about the price.
Thanks in advance.
Greetings from Spain.
Thanks in advance.
Are you sure you didn't reverse those last two numbers? If you did, there are several on Spanish Ebay
https://www.ebay.es/sch/i.html?_from...24670&_sacat=0
TinoSC430 (10-08-21)
I looked for the part number in US. There is a revision part number: 89661-24461-84
Searching for the revision part might show more results in your area.
Not sure if other parts interchange, but the LexusPartsNow website shows it being the same ECU for my 2002 SC430. It also shows that the same ECU was used on at least some versions of the SC300 and SC400 as follows:
Year Make Model Trim & Engine Important vehicle option details
1995-1997 Lexus SC300 6 Cyl 3.0L 2JZGE; 2JZGE; JZZ31L-ACPVFA
1995-1997 Lexus SC400 6 Cyl 3.0L 2JZGE; 2JZGE; JZZ31L-ACPVFA
Keep in mind this is a US site data so I can not confirm if a Euro model would be the same.
Hope that helps
Hope that helps
TinoSC430 (10-13-21)
TinoSC430
If and that is a Big If that 89661-24461-84 part number is correct Megazip in Japan has that part in stock and the cost is $2509. I could not confirm that this ECU is the correct replacement for our 06 SC's but they do have it if you can confirm that it is the correct replacement.
Dennis
Dennis
TinoSC430
Dennis
Dennis
oneround
Good catch. Did not research other sites.
Dennis
Dennis
