2002 sc430 radio issues
Old 10-19-21 | 01:33 PM
Stuckn60s's Avatar
Stuckn60s
Default 2002 sc430 radio issues
I am having issues with my radio fuse(30 amp under hood) blowing as soon as I insert a new one with key off and radio completely unplugged. Has anyone else had this problem? What other components are running through this fuse? Any help would be much appreciated. New member on here.
Old 10-19-21 | 03:34 PM
oneround's Avatar
oneround
That fuse is not switched, i.e., it's hot all the time. In addition to the radio, that fuse also has the amplifier and trunk Nav DVD unit.
Sounds like a short in the wiring somewhere - but I'm guessing you already knew that much.
Oh, and the wiring diagram suggests to me it has something to do with the power antenna relay too.
Stuckn60s (10-20-21)
Old 10-19-21 | 03:36 PM
DshngDaryl's Avatar
DshngDaryl
Is it a new issue, or did u just get the car?
If it is a new issue, did u have any work done to your car recently? Did you put in a new alarm or stereo or anything like that?
Since it is a "Hot all the time" fuse, it is a prime target to attach new equipment to. Possibly some of that new equipment is wired wrong
Old 10-19-21 | 05:43 PM
Stuckn60s's Avatar
Stuckn60s
I have had the car about 10 months. It stopped awhile back but at the time I was working on other things so didn't get back to it till now. The car is stock, nothing as been added.
Old 10-19-21 | 07:47 PM
DshngDaryl's Avatar
DshngDaryl
When you say "I was working on other things" do you mean car things, or life things?
Can you remind me which fuse it is? That way we can google what else is on it.
Also, does you car alarm currently work?
Old 10-20-21 | 10:36 AM
Stuckn60s's Avatar
Stuckn60s
I was working on other things not the car. The fuse is the 30 amp under the hood. Not sure about the alarm as I never use it
Old 10-20-21 | 11:21 AM
DshngDaryl's Avatar
DshngDaryl
I would try your alarm. I think it is on the same fuse, but don't know what for sure.
Like @oneround said, you are trying to find out what is shorting on that fuse.
If you want to see if it is the radio, you can disconnect the radio and amp and put in a new fuse and see if that keeps it from blowing. If it doesn't blow, plug in your amp. If it doesn't blow, plug in your radio. Once it blows, you know the last thing that you plugged in is the problem
JDaveSC430 (10-20-21)
Old 10-20-21 | 02:22 PM
Stuckn60s's Avatar
Stuckn60s
Thanks. I didn't see the answer from @onearound till now. I will disconnect those other accessories and see what happens, will be tomorrow before I can get back to it. Thanks again and will update.
A quick update. Haven't been able to get back to the car yet. My wife had knee replacement and I am playing nurse maid right now. So not much time to get back into the car yet.
theazz
SC430 Classifieds
03-16-18 07:27 AM
jzdulexus
03-05-18 11:42 AM
Ronfeehou
02-25-18 08:32 AM
JennyDrisc
06-18-12 10:45 AM
Mr. Tee
Suspension and Brakes
11-09-10 11:26 AM
