Replacing Brake Fluid
Hello all.....I want to replace my brake fluid (2002 SC 430) and did a search for the correct procedure...found different answers from key on to do rears and key off and removed to do fronts; just do it the standard two person technique or can do it by yourself with homemade bleeder bottle and pump the pedal...can anyone copy the repair manuals copy of the step by step procedure or what way it worked for you..thanks in advance.......
thanks wsvc206.....unfortunately the sites opened but nothing there?......I did do the key method as recommended and things are good..........to be honest, the years old fluid looked pretty good for "old" fluid....pedal was always firm and still is......
Bgw70 (12-11-21)
YODAONE
16
11-08-21 08:41 PM
