No horn
No horn
How long does it take to fix the horn and what parts should i order ahead of time so the car is not out of commission wwhile i wait for parts?
Jim, most likely it’s not your horn, it’s your spiral cable. I hope I’m wrong on this.
Yes, that is what I am also expecting so that is why I want to get the replacement parts in haand before I take it apart. Funny thing is that the Texas Inspection didnt catch it.
You can certainly test your horn by apply +12v to the horn terminal. You will never know, may be it’s the horn.
clockspring? yikes!
Is the proper part number for this part 84306-51030 ??? I dont have any way to check the part number without taking the car apart and its my daily driver.
How much of a problem was the replacement, any tips?
https://www.clublexus.com/forums/sc4...l#post10339477
Remember to disconnect your battery and discharge it to avoid the airbag deployment.
Jim,
The OEM part is like $300 from online Lexus vendors. Check the part number for your order. Or if you went aftermarket, hopefully the part is a good fit and works well for you.
Do a search on Ebay for:
84306-51030 Clock Spring Spiral Cable Fits 2005-2006-2007 Lexus SC430 8430651030
