VSC and VSC off lights came on
After getting a check engine light on my 2002 SC430 found out I needed to change one of my oxygen sensors. After picking up the car from the mechanic I found that my VSC and VSC off light were on. After searching for a solution I found that I could reset these lights and turn them off with the following procedure.:https://www.clublexus.com/forums/att...-dtc-c1203.pdf
I Followed the directions and used a paper clip as my jumper wire.
Yes that paper clip tool has proven to be invaluable! Easier to use than plugging in your your OBD.
