FL Fs 06+ headlight upgrade
Quick sale
$400 for the pair shipping is $450 in two seperate boxes in the U.S. ONLY!
Pictures will be up later tonight with more details
Driver side is JDM and direct plug and play. One tab is broken but mounts perfectly fine.
Passenger side Is USDM and has a tad bit outer condensation on the top but can be buffed out. Two broken tabs and i will post a picture how you can mount it properly. You also need to buy the new 06+ connector and splice wires for the turn signal.
You could buy a bracket from home depot and do better. headlight sits in place and doesn't move. so it mounts perfectly fine.
![](http://i43.photobucket.com/albums/e390/m1sta801/1330205009.jpg)
Includes D4S 6000k low beam bulbs and 5 SMD LED city light
![](http://i43.photobucket.com/albums/e390/m1sta801/1330207025.jpg)
Nokya yellow DRL bulbs included as well
![](http://i43.photobucket.com/albums/e390/m1sta801/1330207246.jpg)
Obviously it will come with the 06+ AFS which you swap out with your old AFS from the old headlight.
sadly missing the passenger side broken tab.. when my car got hit the body shop got rid of it (tab was already broken but was holding the headlight in place)
![](http://i43.photobucket.com/albums/e390/m1sta801/1330994576.jpg)
![](http://i43.photobucket.com/albums/e390/m1sta801/1330994596.jpg)
Driver side broken tab that you can repair
![](http://i43.photobucket.com/albums/e390/m1sta801/1330995007.jpg)
Including the 2006+connector and socket so all you have to do is remove the passenger side turn signal connector pins and connect to the new connector provided!
![](http://i43.photobucket.com/albums/e390/m1sta801/1330995139.jpg)
Ready to be shipped out!
![](http://i43.photobucket.com/albums/e390/m1sta801/1330995153.jpg)
Mistasc. I would love these for my sc build to upgrade. Can you email me at tommyt85@gmail.com with a hookup price.
Yes. Normally you would have to "splice" both headlight turn signal connectors but since one headlight is JDM the turn signal connector is the same. So only for the passenger side you gotta buy the connector for the turn signal and change out the old pins and plug it into the new connector. You actually dont have to "splice" anything if you remove the pin on the old connector properly.
If I had to do it over again I would use a T tap and add another wiring with pins and tape up the old connector. installing the new connector to the new removeable wires with pins. smartest way to convert back.
you would need an 06 front bumper, grill, 06 trim pieces to complete the bumper to make it fit perfectly. I shaved the corners of my 02-05 bumper since the new headlights are sharper. other then that its a pretty good fit as seen from the pictures posted
TLW
03-01-23 11:29 AM
masboy
10-05-12 11:56 AM
