What did you do to your SC today?
#6947
Continued the GTE ECU swap.
Tested the injectors and checked for leaks
Wired up the igniter and the coil packs
Wired the IAT and MAP sensor
Tomorrow, i hope to conclude the ECU swap with a smooth running engine.
Concluding steps:
Reinstall manifold Y pipe and throttle body
Install IAT
Feed new wires into the car
Rewire stock GE harness to work with GTE ECU
Plug MAP sensor in
Install new ECU
Test!!
Concluding steps:
Install IAT
Plug MAP sensor in
Install new ECU
Test!!
Boergy (10-28-17)
#6951
Hosed my factory 91 12 disc CD changer trying to clean the lens. Anyone got a spare stock plug and play non Nak changer laying around? Im also going to reflow the head unit as I think I got a cold solder joint on the preamp portion as the CD player sounded crystal clear (when it worked) but the FM sounds like its playing out of overdriven 2 watt telephone speakers. seems to fade back in about 15 minutes into a trip if Im lucky, otherwise it just sounds like crap.
#6954
#6956
The passenger side seems to have the inner side of the blade touch the wiper arm. Not sure if it affects the performance of the swipe. Didnt want to try it yet cause i just washed the SC.
part # 00910 for the sticker.
Where would you put the sticker?
#6958
Replaced Window regulator - 95 Sc300
Spent 3 hours replacing left side window regular. Hour and half was just removing the two screws 14mm that hold the window. (Need lots of patience)
They’re practically flat heads. Got brand new original OEM Lexus part from eBay Lexus seller for major savings.
#6959
I am glad to see that you got the wiper blades on your SC. I still have the same wiper blades on my car for almost 2 years now and they still work great! I did not notice that the passenger blade touches the arm until I read your post. I have not had any issues on my end from that so you should be good.
