Auto headlights not shutting off
Old 11-06-17, 01:36 PM
djamps
djamps's Avatar
Default Auto headlights not shutting off
Hi all, haven't posted in a while about my 98 LS400. I recently started having an issue with the auto headlights not shutting off after leaving the car.
I know the first thought would be door, trunk, hood sensors. Tested all of them and they work normally. Open door/trunk/hood indications in the cluster also work normally.
Here's the most interesting part -- even with a door ajar, you can normally kill the lights by arming twice. This no longer works... the lights stay on no martter how many times you arm.
They turn on/off normally while driving depending on light level -- they only stay on and refuse to extinguish when shutting down after dark, and will run the battery completely flat unless manually shut off.
Thanks for any clues!
Old 11-06-17, 05:51 PM
sha4000
sha4000's Avatar
I used to have this issue from time to time. I would just manually shut them off. Sometimes they would go off and other times they would not. I never did anything to fix it and just chalked it up to the car being old.
Old 11-07-17, 04:46 AM
fixmiester
fixmiester's Avatar
Default Relay issue
Sounds like a problem in the headlight delayed turn off circuit; I'm not sure if it uses a physical relay, or a solid-state control, but it's stuck on, which bypasses all the other controls, except the OFF switch.
Old 11-07-17, 09:38 AM
djamps
djamps's Avatar
Anyone know which module controls this? I wonder if I have degraded caps, ect.
Old 11-07-17, 06:34 PM
YODAONE
YODAONE's Avatar
Body ECU?. Some factory wiring diagrams to assist in your trouble shooting efforts...
saleenssc (11-08-17)
Old 11-07-17, 09:32 PM
djamps
djamps's Avatar
Thank you YODAONE!
So looking at the diagrams it seems the culprit is most likely the "body ecu"?
Old 11-08-17, 07:00 PM
YODAONE
YODAONE's Avatar
Thank you YODAONE!
The Light Control Switch connects to body ECU.
Old 11-08-17, 10:13 PM
Yamae
Yamae's Avatar
At first I'd check the relay's contacts to see how one side is convex (pip) and the other concave (crater). I have seen many relay problems such as a situation of dog's intercourse.
This is common problems among aged DC relay's contacts that carry big current.
Old 11-09-17, 05:45 AM
fixmiester
fixmiester's Avatar
Default Need to Google that
"situation of a dog's intercourse" . Never ran across that one before, although I've often filed relay contacts to remove deposition fouling deposits. Wish I could find an emoji for that!
Old 11-09-17, 06:37 AM
Yamae
Yamae's Avatar
http://www.esterline.com/Portals/3/H...ure%203.1c.jpg
1halifax
NX - 1st Gen (2015-2021)
12-10-15 06:19 AM
sktn77a
04-30-14 07:22 AM
dickparker
Lighting
01-04-14 01:30 AM
Spacepig
03-25-09 11:51 PM
sonyman
08-17-05 06:04 PM
Quick Reply: Auto headlights not shutting off
