Off Roading
#107
^^ Pretty good video but crappy music choice
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
#108
So crawl is 5 different speeds? FSM seems to suggest that. I assume DAC on "non-crawl" models is basically a fixed speed downhill crawl control. I've used it a few times on steep hills. There is mention in FSM about overheating issues if used for extended periods of time.
Crawl Control - 1 to 5 MPH
DAC- appears to be around 3 MPH
#109
![](https://www.clublexus.com/forums/images/ranks/rank-smod2.gif)
https://www.clublexus.com/forums/gx-...l-control.html
For crawl control if it was just a BCM and console switch swap like in the 4Runner...might be something for me to think about.. not positive a new master cylinder is needed though. I notice '10-'13 they had standalone crawl available as an option but I can't say I've seen that unicorn. That might be rarer than the GX's without nav.
![](https://cimg5.ibsrv.net/gimg/www.clublexus.com-vbulletin/391x495/screen_shot_2018_01_01_at_4_08_20_pm_db98346a0979f53a239f157007ca7728cfa02f3d.png)
This guy retrofitted his '15 4Runner
http://tctmagazine.net/spring-2016/2...ntrol-retrofit
#110
Older video from 2010 showing KDSS comparison of 150 series to 120 series, Discovery and Mitsu Pajero
#111
You have the full Driver Support Package on yours?
#113
I would have wash the seat afterward... pucker factor
![EEK!](https://www.clublexus.com/forums/images/smilies/eek.gif)
#114
Looks like at ~1:45 he put in 4L and possible center diff to utilize ATRAC. For those that don't know... keep under like 2200RPM or so for ATRAC to work best.
#115
Just speculation but I don't think splicing would be necessary on the GX... just a console with the crawl switch on it. There were some physically absent switch assemblies on the 4Runner.
#116
Are you saying that the wiring could potentially be there and all that would be needed is the switch installed??
#117
That very well could be.... I've thrown this out there to give thought to the adventurous souls who want to travel the path first :-)
At minimum a new switch and a BCM. The big expensive if....is if a different master cylinder is needed. The BCM new is not too bad at around $500...used probably half that. The 4Runner guy didn't need the master cylinder replaced.
Some more info I posted in a different thread.
If all the connectors on the wiring harness side of console switch are terminated in the connector then a major piece is already done.
#119
Another trip yesterday
#120
Nice, thanks
![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
