TPMS / TPWS Questions/Comments/Concerns
#136
Thanks for trying. Bummer that it doesn’t work.
ODB Fusion has some addon extra settings and features in their app for Toyota and Lexus that have more functions. I wonder if it can display that info via the wireless ODB. I have the app and will try to get the addons.
#137
Is ODB typo for OBD?
#138
![](https://www.clublexus.com/forums/images/ranks/rank-smod2.gif)
#142
![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
Acrad (01-06-18)
#143
I am pretty sure it can only read data at the valve stem. Because in order to read the data, it requires to send the trigger signal to the transmitter, The TP401 has no mechanism to register and save the transmitter IDs, therefore, it is no way to do a dynamic receiving without knowing which wheels are talking. That is my non-automotive terminology wild guess ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
#145
Yes, one at a time starting from always Left front to right front right rear and left rear always in that order. You go around the vehicle CW.
#146
Not sure if that's how it works.... You trigger the sensors (as you described in order), it records each wheel pressure, that's it! in order to do another reading, you have to trigger it again, and in fact, the unit will ask you if you want to erase the previous data before even entering the triggering mode. Unless there is some tricks that I didn't know to make it a real time reader.
#147
What I wonder is vehicle with TPMS tells which which wheel has tire pressure problem. Isn't that enough? New cars are coming with more and more Run Flat tires.(I don't like this tires, costs more, gives hard ride)
I carry little 12V compressor with gauge in the trunk. If I get pressure warning I pull over. Inspect tire and rim if I can;t see anything obvious I pump up the pressure, keep on driving. At first possible time and place
I take the wheel off, check it out patch the tire, replace tire or remount it to reseal the bead.
#148
#149
