oil consumption
Old 02-14-18, 11:09 AM
RAMBLER2
RAMBLER2's Avatar
Question oil consumption
I'm on an extended trip from Canada,touring Texas and Southern states.Putting lots of miles on but having trouble checking oil level with the dip stick,no clear mark.Question-is there a low level oil warning on these gs350s?I have added a quart but do not want to over fill.
Old 02-14-18, 11:26 AM
bclexus
bclexus's Avatar
Fresh oil is sometimes hard to see on the dipstick. Allow the engine to be off for 5-10 minutes and check the level. You may want to try to wet the dipstick with water or windshield washer fluid before re-inserting it into the dipstick tube - that will sometimes provide a better 'read' on where the oil level is.
It is very doubtful that your engine is consuming any oil...likely no more than ¼ quart in 10,000 miles. If you have added a full quart, chances are good that you have overfilled it 'if' whoever changed your oil last time put in the correct amount ...which leads to the question - who did your last oil/filter change? Was it a Lexus dealership? Or, some quick oil change place that hires high school dropouts, drug addicts and delinquents?
Old 02-14-18, 11:34 AM
RAMBLER2
RAMBLER2's Avatar
Yes dealership (never again what a rip off)I will try your tip to get a better read.Is ther a low level warning?my beemer had a very good system for checking oil,with a warning for 1Qt top up and no dip stick!
Old 02-14-18, 11:37 AM
bclexus
bclexus's Avatar
Yes, there is a low engine oil level 'idiot light' on the instrument cluster, but I do not know at what [low] oil level the warning indicator comes On at.
Old 02-14-18, 12:05 PM
er34
er34's Avatar
No dip stick means it's a "very good system" !??? what ????
Are you wiping off the dip stick before you take the reading? It should be pretty easily visible under light. Try doing it outside in the sun.
Old 02-14-18, 02:00 PM
RAMBLER2
RAMBLER2's Avatar
Yes good system, can always know what the oil level is and indication when a top up is required before it is critical.Low milage Beemer but did need topping up before next oil change.Ok good to know that there is an idiot light thanks.Yes I am wiping off the stick but it smears for some reason,leaving no clear line.I have owned lots of cars and never had this problem.
Old 02-14-18, 02:19 PM
Knucklebus
Knucklebus's Avatar
First, is the car off and has sat for at least a few minutes on flat, level ground?
Second, what does the oil look like on a paper towel when you wipe the stick off?
If you wipe the stick, reinsert and promptly remove the stick, I've never had a problem reading the oil level, assuming oil is actually on the stick.
If you've added a quart too much, you probably haven't hurt anything as long as the crank stays out of the oil. These things hold more than 6 qts so 1 qt low would not worry me unless I was running it at high RPM for extend periods.
Old 02-14-18, 06:34 PM
maveriCK..
maveriCK..'s Avatar
i also have this problem..it is very hard to see the oil level on this car lol
mine also "smears" when pulling it out to check like the op said..
you just have to look very closely at the dip stick.
i guess our oil is just too new.
Old 02-14-18, 06:51 PM
bclexus
bclexus's Avatar
The dipstick tube is angled such that the oil on the dipstick wipes off on the inside of the tube and smears on the dipstick, making it difficult to 'read' the level of the oil. To overcome this, pull the dipstick out of the tube as soon as the engine is turned Off and wipe it clean - then wait at least 3 minutes before inserting the dipstick back into the tube and pulling it out to check the oil level. This will allow enough time for the hot oil that was on the inside of the tube to drain back down the tube so it will not smear as easily on the dipstick. The smearing will then be minimized because the smearing will only be from pulling the dipstick out, not from both inserting it and then pulling it back out.
Also, wetting the cleaned off dipstick with water (or windshield washer fluid that is nearby under the hood) helps improve the 'read' of the oil level...because oil and water don't mix, thus there is a separation of the two fluids.
maveriCK.. (02-15-18)
Old 02-16-18, 03:16 AM
RAMBLER2
RAMBLER2's Avatar
It is for low pressure,so too late when that comes on I think.
Old 02-16-18, 06:14 AM
TCH2FLY
TCH2FLY's Avatar
Cool
sorry that is pressure not level
you are exactly right, when you see that you should be prepared to spend $$$$. I can’t count the number of times I had customers tow cars into the shop saying “ it should be ok the light just came on “ only find a blown engine
Old 02-16-18, 12:50 PM
bclexus
bclexus's Avatar
Correct - a wavy line underneath the oil can means the engine oil is low. However, I am not sure that the Lexus GS 350 has such a warning indicator.
The link below provides the Lexus IS Warning Lights. In looking at the GS 350 warning lights I do not see this oil can in yellow (meaning it is a 'reminder' to get the car serviced), nor do I see the oil can with a wavy line underneath the oil can (meaning the engine oil is low). I have to assume there is likely no indicator warning light for the engine oil being low.
Engine Oil
This is the oil pressure engine light. If you have a wavy line underneath the oil can, it means the engine oil is low. Stop the vehicle, turn it off, and check your oil. You never want to drive with low engine oil. If there is a warning in yellow that says "OIL LEVEL," this is a reminder to get the car serviced.
Old 02-16-18, 04:22 PM
TCH2FLY
TCH2FLY's Avatar
Not sure about other years but my 2017 GS the low oil level is under master warnings and uses simple text
Attached Thumbnails oil consumption-19c58ec6-0811-492c-9d33-776d08dff840.jpeg
Im2bz2p345 (04-01-18)
Old 02-17-18, 04:45 PM
RAMBLER2
RAMBLER2's Avatar
Thank you very much,it shows the same info in my 2015 manual.
Old 03-31-18, 07:28 PM
RAMBLER2
RAMBLER2's Avatar
I now have an accurate way to measure oil level,clear plastic tube cut to length.The inside gives a clear mark.So having topped up with a Qt of oil 5000km ago the engine is slightly overfilled.Conclusion is that over 10,000km the engine has used very little oil,and the overfill has not been a problem.
lilativan
IS - 1st Gen (2001-2005)
01-22-19 10:14 PM
LesR1200RT
RX - 3rd Gen (2010-2015)
09-24-18 06:15 AM
lysis250
05-31-14 06:12 PM
reisjdmd
RX - 1st Gen (1999-2003)
17
07-30-12 08:08 AM
maximussp
06-04-08 04:06 PM
Quick Reply: oil consumption
