95 sc300 1jzgte non vvti daily build
Hey guys im currently building a 95 sc300 that I picked up from a old member on here. The car is pretty clean but has its flaws here and there. Doing a 1jzgte non vvti swap and keeping it automatic. I will post pictures as I go and you can see the progress of the car.
Recent things that I have done
pulled motor and parted most of the stock stuff.
Installed new oil pump, water pump, valve stem seals , valve cover gaskets , plugs, powder coated everything that would fit in the oven lol
cxracing thick wall manifold and tial 44 wastegate
set the timing and that jazz
here are the pictures
Hope to get help. Changed the water pump and timing belt on 95 sc300. Was careful to not lose the timing by marking the cam position as well as the crank. Runs great when cold but after warm won't run good at all. Adjusted the distributor, runs best all the way to the left ( down ). What to do? Can I remove and testable the distributor? Also I read in a post I need to jump two positions on diagnostic plug??? Please explain Jump to what?
here are some photos guyssss.....
New radiator due to age and the oem falling apart..
thick wall manifold t4 for some boost
scooped a mk4 supra hks exhaust
bought a wire harness on facebook that was supposed to be complete... ended up re doing the entire harness ... twisted wires with electric tape ....
adding 440's from a aristo I had laying around
cleaning the bay out
towing the sled home
can you say some solid phr mounts?
cleaning for some fresh powww powww
new valve seals installed.... I dunno what I would have done without this tool
dirty covers pre media blasting
motor how I picked it up from GIS GUy
she chilling!
coated parts
motor and front
turbo goodies
she chilling!
coated parts
motor and front
turbo goodies
Looking good.. Cant wait to finish my 1j swap.. still waiting on some parts to come in haha. Im hoping to have my car done by springfest in VA beach.
so what throttle cable am i supposed to use? i saw you can use the 94 camry one and a supra. i want to keep the trans pressure line in the same place so what all do i need to do...?
Hoytenki
IS - 1st Gen (2001-2005)
10-24-17 08:05 PM
devinb30
Performance & Maintenance
01-12-13 10:14 AM
