Possible Custom Intake
Old 06-13-16, 03:29 PM
MDHLexus
MDHLexus's Avatar
Default Possible Custom Intake
Should I go about trying to create this? Here is a little mock up I did in SolidWorks... It would be basically one of the short ram intakes on the market, but I would cut a hole to have the stock cold air intake line up with the box. The set up would use a cone filter instead of a flat filter. So essentially keeping the same design of the stock airbag to serve as a heat shield and funnel for cold air. Also would have a hole cut out to make it like the Fsport lower box.
Old 06-13-16, 04:11 PM
MWIS350
MWIS350's Avatar
I like it you should also make cover for bottom.
Old 06-13-16, 04:12 PM
MWIS350
MWIS350's Avatar
I like something like this..
Old 06-13-16, 04:44 PM
bbaugher47
bbaugher47's Avatar
I have this ( not my car) when the plastics are on the filter is enclosed fully. Takeda is the manufacturer. AFE sister comapny
Old 11-04-16, 01:17 PM
soleeasii
soleeasii's Avatar
did you ever fabricate this intake?
lexus-is2
Performance
17
02-13-19 12:35 PM
ISF001
RC F (2015-present)
18
06-30-17 11:17 AM
Raycow
01-05-16 08:36 PM
sgv_bum
16
10-29-12 12:30 AM
Katin2
Performance
07-09-07 10:44 AM
Quick Reply: Possible Custom Intake
