What happens to your front tires after swift springs and RR bushings and no alignment
^^^^^^^^^Thx I'll keep that in mind if after my alignment and new tires and they start to exhibit the same uneven wear pattern then I will definitely look into something like this!
I am running the Figs LCA bushing, with swift springs (front only) for about 5K miles on my new tires. I just completed a swap to BC coils this weekend and did a thorough inspection of all the tires. They are wearing evenly. Alignment was set to 0 toe.
I agree, it's definitely toe wear which can be solved relatively easily with an alignment.. Camber doesn't kill tires like that. It will just show a progressive tread loss across the width of the tire because of the pressure of the vehicle. Tires with that kinda wear your essentially dragging your front tires down the road. As you know our cars have a issue with toe deflection under braking but can be fixed with rr bushing or figs or I bought rc-f bushings and so far so good.. We will see!
Thanks for the upload of your alignment specs I will post mine when I put it on the alignment rack after I get my new tires and see how bad it was before and then the after specs.
my inner tires were worn badly also. I think its from the toe angle changing during loads. I've been running the RR-racing usrs to hopefully combat this wear. so far it appears to have stopped the abnormal wear (1 season on new tires)
you guys do realize there is a thread on alignments started by our own admin Lance....
https://www.clublexus.com/forums/is-...alignment.html
Wow. At those mileage numbers you as well track it . All jokes aside make sure you realign after ever set of tires . Also if you are lowered this is the nature of the beast. The F is damn heavy and that big V8 sitting over the front wheels is no feather weight either . An alignment should help. Also for reference Nitto makes a tire that is designed for lowered cars . ( could be toyo ) . Google it . Might help too
^^^^^Appreciate it! Lol........yea lesson learned, I could've tracked the car with those miles, definitely going to do an alignment with my new PSS tires going on probably next Tuesday when they're delivered
