fuel filter question
Old 09-13-16, 12:31 PM
lextout
lextout's Avatar
Default fuel filter question
any one on there original fuel filter? and do we need to change them out? i changed my fuel pump by not the fuel filter.
Old 09-13-16, 06:00 PM
Mcon
Mcon's Avatar
lexusout,
Check out these links;
https://www.clublexus.com/forums/gs-...-filter-5.html
https://www.clublexus.com/forums/gs-...el-filter.html
https://www.clublexus.com/forums/per...s-at-100k.html
Old 09-13-16, 06:03 PM
mate01
mate01's Avatar
when do these usually fail?
Old 09-13-16, 08:10 PM
Mcon
Mcon's Avatar
Mateo,
Is good to change it when you car get 100,000 miles. This was like a year ago.
OEM part number. This is for GS300
Check on eBay this item # 252418259778. I buy on the dealer cost me just a little more. LOL
Old 09-13-16, 08:14 PM
Mcon
Mcon's Avatar
Look at the difference of the old one and the new one.
Old 09-15-16, 04:46 AM
lextout
lextout's Avatar
did it come with black plastic can type housing ? or did you just buy the filter? theres one on there 35$ and 8$( fuel pump filter?) i replaced my fuel pump with the filter it came with.
Old 09-15-16, 11:37 AM
lexo98
lexo98's Avatar
if I remember correctly I replaced both
Old 09-15-16, 03:09 PM
Mcon
Mcon's Avatar
Is coming with it, if I remember correctly.
Old 09-27-16, 01:03 PM
lextout
lextout's Avatar
Default fuel filter
whats the difference between a fuel filter and a filter suction aka fuel screen aka fuel strainer, thanks in advace.
Old 09-27-16, 04:36 PM
badblackgs
badblackgs's Avatar
the very bottom of the fuel pump has a little flat "sock filter" attached to it. the main fuel filter is built inside of the fuel pump assembly.
Old 09-28-16, 05:22 AM
lextout
lextout's Avatar
OK that's the fuel filter what about the strainer and filter screen
Old 09-28-16, 04:48 PM
firelizard
firelizard's Avatar
What are you talking about?
The guy just told you what two filters are in the car. There's one on the end of the pickup (part #23217-46090), and one inline with the pump (part #23300-21010)
Old 09-28-16, 07:40 PM
MattyG
MattyG's Avatar
OK that's the fuel filter what about the strainer and filter screen.
If you look down at your gas tank after you've removed your rear seat cushion and taken out your fuel pump assembly, you will see a "sock" at the bottom of the whole works. That's the fuel strainer or sock. The filter is actually inside the assembly.
One is cheap, at your local Toyota dealer. The other one, well you have to decide. Personally if this is not your thing, I would just order the whole works online and swap it all out as one.
Originally Posted by firelizard
The guy just told you what two filters are in the car. There's one on the end of the pickup (part #23217-46090), and one inline with the pump (part #23300-21010).
I don't think the guy has actually stared down into his gas tank so maybe he's just wondering if it's a diy... or not.
wwwjogos (01-19-20)
gripau1
11-17-22 07:28 PM
SorrGwa
06-18-09 09:27 AM
jbw
04-15-08 03:28 PM
Benjamin T
Maintenance
09-22-06 12:32 PM
ginjuice
Performance
01-12-06 08:12 PM
Quick Reply: fuel filter question
