Aggressive fitment IS-F pics!
Old 09-26-16, 11:27 AM
  #946
shyguyF
shyguyF's Avatar
I think it will work bc your fenders have been shaved. With 9.5 +35 the outer edge will be 26.5mm sticked out compared to the stock wheels 9" +55. And I think 285 on 9.5" looks better than 285 on 9".
Old 09-26-16, 11:29 AM
  #947
zmcgovern4
Auto Detailing Master
zmcgovern4's Avatar
Originally Posted by Max16
What do you guys think about a 19x9.5 +35 in the back using a 285/30? Tried searching this setup and only cam with results on stock wheels.
My fenders are trimmed.
I have 19x10 +40 in the rear with 285/30 (basically the same as your 9.5 +35). Fenders are rolled and I only rub on big dips at speed. 99% of the time there is no rubbing.
Old 09-26-16, 11:33 PM
  #948
ljdsong
ljdsong's Avatar
Look up my post page 938, thats 285/35/18 +35 it rubs at tha edge where the bumper and fendermeets,even my fender rolled and pulled still rubs at the top most of wheel arc. I suggest get the 275 wide tires.
Old 09-27-16, 05:42 AM
  #949
Max16
Max16's Avatar
I want 285/30 not 285/35
FN_Darknes (06-07-24)
Old 09-27-16, 07:46 AM
  #950
Flogrown
Flogrown's Avatar
I'm running 19x10.5+35 on a 285/30 tire with a roll and slight pull. I only rubbed on the bumper tab, I was tucking with less than an inch from the lip. I raised it up 1/2 an inch and don't hit the bumper tab anymore, so you should be ok.
Old 09-27-16, 10:02 AM
  #951
Durrby
Durrby's Avatar
I'm looking at a set of AG M510's on craigslist. The listing says their 20x10 +35 with 235/35's all around. With a stock height car will I encounter any clearance issues? I tried to skim at least the last few pages and it seems I might be good. Seller said he's unsure of fitment with BBK's though.
Old 09-27-16, 10:27 AM
  #952
Flogrown
Flogrown's Avatar
Durrby you should be good my previous set up was 19x10.5,+16 with a 235/30 tire they were stretched. I was lowered as well and didn't have an issue. Even though you may get 20's I don't see it being that much of an issue. I used to run a set of Weds that was 20's at stock height with the offset of +24 without issues as well with just a roll.
Old 09-27-16, 11:09 AM
  #953
Durrby
Durrby's Avatar
Thanks for the fast reply! How about inner clearance, were spacers needed to clear the brakes/struts?
Old 09-27-16, 11:10 AM
  #954
flowrider
flowrider's Avatar
Received 1,916 Likes on 1,351 Posts
We're talkin' 18" vs 19" here. 285/30/19 and 285/35/18 have the same OD.
Lou
Old 09-27-16, 11:22 AM
  #955
Flogrown
Flogrown's Avatar
No issues with inner strut clearance, I have a set of CCW's that are 13 inch wide that fit as well, they just poke out the sides. I'm kinda a week *****. If I keep the F I might do the Lexon wide body.
Old 09-27-16, 03:21 PM
  #956
ROYALISF
ROYALISF's Avatar
You'll be good. I'm running 20x10 with a 275/30 on all 4. I have the rears rolled and only rub on deep bumps otherwise its fine.
Old 09-27-16, 04:14 PM
  #957
ljdsong
ljdsong's Avatar
Understand that! You want the 19s and my set up is 18. Im doing my fender rolling and pulling by my self and my previous set up is 275/19 and no problem with pulled and rolled fenders. Im saying your safe with 275. They're saying raised up 1/2 inch, if you have coilovers, but how about if you stock and have passengers. It will rub still. You can get away with the rubbing only if you get a neg camber.
Old 09-28-16, 01:09 AM
  #958
Meraki Autoworks
Your #1 Lexus Vendor
Meraki Autoworks's Avatar
Meaty..
-Josh
__________________
Orange County, CA
Text/Call: 213 394 2886
Old 11-06-16, 10:47 PM
  #959
terryvly
terryvly's Avatar
Originally Posted by 318ISF
Thought I'd share a few more.
perfection
Old 11-07-16, 05:30 AM
  #960
Eminence
Eminence's Avatar
B8bydesign (02-11-20)
Quick Reply: Aggressive fitment IS-F pics!
